Don't neglect the basics
  • Don't neglect the basics
    Just some musings from my trip as the passenger in the friend's car. Three of us went hunting in Victoria's Hight Country, about 30 km from Benumbra. Except for the unexpected bitter cold at nights the trip was great, and my fridge has enough venison to last a few months.
    To the point. On the way back my friend decided to take the shortcut through the mountains. Beautiful scenery, quite rough - but he has jacked up Ranger and could handle it without problems... Until. Half hour into the trip I casually asked him:
    - Are you on low gear?
    - No, it's been fine like this,
    - Are you using gear or crawl on descents?
    - No, just the brakes,
    - You didn't deflate the tyres?
    - No, seems to be fine...
    Five minutes later on top of the long descent (about 250 meters down) my friend's face gets serious: "I think we have trouble". He is pressing on the brakes, but the car keeps slowly going down the hill. He tries to switch on the crawl system, but gets the message that the system is overheated. He puts the gear in parking, and after several seconds of slowly sliding on the gravel the car stops. I take over the pedal and suggest that we tie the car to a tree and then figure out what to do next. Mind you, it took some time to find a strap which was buried under the luggage. The reason for the trouble was that the brakes overheated and could not stop the car.
    After about half hour the brakes cooled down an we safely descended. Luckily, this descend was the last bit of the rough road, and about a hundred meters later we got onto the bitumen.
    I am new to off-road driving and just did the Toyota Landcruiser Club course couple of months ago. This friend of mine has been going off road for the last 20 years, and I thought he knew what he is doing. I guess with experience comes complacency, hubris and arrogance.
    This little incident has been a good lesson for me. Do not neglect the basics, never mind how experienced you are. Australia is a really strange place, with the existence of modern civilisation and extreme wilderness within hundred kilometres. Drive couple of hours away from Sydney, and you can get lost and die in the Blue Mountains. Things can go wrong so quickly and so badly. The patch of the road we were at was about 18 km long. Seems not that bad, but imagine getting stuck in the middle of it and breaking the leg or getting bitten by a snake - that's the example of things going downhill quickly.
    My lessons from this:
    - Deflate tyres every time you go off road, especially if this terrain is new
    - Do not get complacent - switch to low gear and use descent techniques; a few litres of fuel are worth the safety
    - Prepare - recovery gear should be at hand, not buried under the stuff
    - Seriously consider getting a satellite phone when going to remote areas. It's about $150 a week, definitely worth extra assurance if you get stuck.
    - Probably most important: do not rely on your friends' experience and don't be shy to question the level of their preparedness.
    Your friend has At's or road tyres is my guess for the fun parts of Victoria Mt's are a must. Wind the window up when you get bogged is my tip of the day
    I got myself some Big Horn Maxxis and was telling my landrover lover mate he said what size did you get I told him 265/75/16 he said I didn't know they came that small.
      Ummm. He did try the handbrake didn't he?
      Usually last resort before trying to blow the park lock off the gearbox....😐
        He didn't. That's another pointer at the lack of competence. The car was sliding very slowly, so switching to parking seemed ok.
        To the previous point - he has fat MTs. I reckon it does not replace the skill.
          Sounds like a problem with the Ranger as much as anything, even a clapped out kingswood wouldn't suffer from overheating brakes taking a "short cut"
            Neglect
            One reason the brakes boil quickly is the brake fluid absorbs moisture and over time this can build up, that is why brake fluid should be changed regularly every 2 years.
            This happened to one of club members in a auto landcruiser after a long drive constantly braking for about 15 minutes going down a mountain range brakes boiled and stopped them working all together, she did not know when the fluid had been changed not in the last 5 years that she knew.
            Check with your friend to see if it has been a long time since changing his fluid as well.
            2001 3Lt Manual Diesel, Safari Snorkel, ARB Winch Bullbar, Hella Spotlights, 9000lb Warn Winch, Dual Battery, Couplertec Electronic Rust Prevention, Glind Hot Water Shower, ARB Front and Rear Air Lockers,Onboard Air Compressor, DP Chip, 40mm OME Lift, Steel Slider Side Steps, GME 3200 CB Radio, Milford Cargo Barrier, Extended Diff Breathers, Draw system and Fridge Slide, 40lt Engel Fridge, GPS with Wireless Reversing Camera, Rhino Roof Racks with Aluminium Tray, Awning and Drop down Table on Rear Door.
              Great story, thanks for sharing. Main thing is you both are ok. And only a novice would solely ride the brakes down a steep hill. Use low range 1st for steep descents. Hate to think how he was driving when he first started out haha.
              Yeah I had a couple of friends who went to the high country in January last year and said most of the nights got down to zero degrees.
