Hi all.
A puzzling (probably disappointing) question re vehicle weights.
I have a 2016 Prado Kakadu V6.
Its current weight including fitted accessories and two people is 2650kg.
If its GVM (Gross Vehicle Mass) is 2900kg, am I assuming correctly that this means I can only add 250kg of luggage to the Prado when traveling i.e 2900-2650=250?
Whilst this is probably enough storage capacity, my recovery gear, including second spare tyre, probably weights close to 100kgs which then only leaves 150kgs of luggage weight.
If I add a caravan with a tow ball weight of say 180kgs, am I correct in deducing that I am 30kgs over weight?
If so, I guess the Prado is virtually useless for towing anything except a box trailer.
Now I know from reading caravan forums that there are plenty of Prados out there towing caravans, mostly around 20 feet.
So, should I not carry a second spare?
Should I forget about caravaning until I get a V8 Landcruiser.
Do I assume that all those dinky toys out there like DMXs, Rangers, BT 50's etc are really kidding themselves re what their compliance says they can tow, given that I would think that my Prado is stronger and more powerful than any of these.
If there are any of you out there that has similar weights is there an answer other than no second spare or recovery gear (could leave the wife home I guess but then she does have her uses!)
Any advice, especially if I have got it all wrong, would be appreciated.
Cheers.
Disappointed Dave!
(should have bought that V8 Landcruiser GXL which would have been cheaper anyway!!!!
Cheers.
Disappointed Dave!
photoprado
