KAKADU:Squeaking from front right suspension.
  • KAKADU:Squeaking from front right suspension.
    Hello,
    For some time now I have noticed a squeak in the front right suspension, this gets louder when going over speed bumps. On smooth roads it is non existent. I have put the car in for service and they told me they have found nothing
    Does anyone know what is the problem. Suspension does not squeak on the latter 3 wheels,but only on the front right drivers side.
    thanks
    Most likely a squeaky bush.. How many kms on the car?
    Get someone to lay under it and bump the front up and down by hand as hard as you can, the squeak should appear.. A squirt of lube will sort it out in the short term and identify the spot.
      I've had two similar problems with a 120 series (I'm guessing you have coils under the front):
      1. Top mount of front shock had loosened up causing some movement and noise. I had just dropped it into a washout on Fraser Island at a little too much speed, so might not be plausible for you!
      2. The wheel arch shroud (plastic between the engine bay and wheel area) has worked its way lose (I think it was just one clip) and this caused rubbing between the body and the plastic.
      If your car is newish, its most likely to be Piggy's suggestion, but you never know.
      I hate rattles and squeaks!
      2004 GXL 1KZ - ARB Deluxe Winch Bar - Safari Snorkel - Dobinsons/Ironman suspension - BFG AT 265/65/17 LT
        100000km, so this the front circular tube like structure behind the wheel.
