Off Road Trailer couplings Hyland v AT35 v Tregg
  • Off Road Trailer couplings Hyland v AT35 v Tregg
    Greetings guys
    I would like to know what coulpings people use on their CT's. I have used the Tregg on my All Terrain However i have just sold that one and i am about to order a modcon and they have the option of the AT35 or the Hyland.
    What are your thoughts on what you have or what you have heard from mates with something else. I have heard the Hyland can be a bit noisy like a standard trailer and the AT35 is a pig to line up.
    Is this right?
    thanks Adds
    ...My batteries need recharging i need to get away...
    Hi adds,
    I have an AT 35 on my Trackabout camper. It has worked faultlessly over some pretty tough terrain. The only adverse comment I will make is that it is a bit of a bugger to hook up in sandy conditions. Apart from this it is excellent.
    Kevin
    2008 Silver GXL D4D Manual. Arb Steel Bar,Warn Wnich,IPF Driving Lights, GME UHF,Dual Battery System, ARB rear airlocker,Milford Cargo Barrier,OME Suspension, Cooper ST's.Trackabout Off Road Camper.
      I have an AT35 on the Trackabout (for sale) and found that it worked very well. Quiet, strong but I have had problems hooking up in less than ideal conditions like my steep driveway. I have to haul it up on a tow rope and attach at the top. No big prob.
      I now have a Jayco Outback Eagle and had a Hyland installed. Love it. It gives the flex but also the convenience of dropping the hitch straight down on the ball. So much easier! Easier to line up. I have no probs with noise. Noise means no grease!
      Dirttracker, (Martin)
      Prado GXL '05 Diesel.
      [url="http://picasaweb.google.com/mpnaylor"]http://picasaweb.google.com/mpnaylor[/url]
      [img]http://i197.photobucket.com/albums/aa48/dirttracker123/DSCF5442-1.jpg[/img]
        Thanks Martin for the feed back you are the first person i have heard from that has had both to give a good comparo.
        Kroe thanks I know the AT35 goes realy well once hooked up however i have recieved similar comments about hooking it up.
        thanks Adds
          Here's a site I found that sells most offroead hitches- http://www.trailerwarehouse.com.au/inde ... =d218.html
          I use a hitch called Nathan Hitches from the US, its very close to the Orac pictured. It does its job fine, although when I detach to camp I take the entire hitch off the towbar rather then stuffing around with the pin when reattaching.
          97 Vitara 1.6 JX Day Tripper(550klms range), 98 Prado V6 LPG GXL for Touring (1400klms range), Offroad Cub Camper for Overnight.
            Hi Adds
            I had a Treg coupling on one of my off road caravans. After finding it quite difficult to line up, I went for a Hyland. I have never looked back. It swivels in all directions and you just have to line it up (quite) closely, kick the van's drawbar and it clicks in.
            When I ordered my latest Kedron off road van, I specified that it be fitted with a Hyland. Only way to go.
            BTW, I have never seen the AT35 so I can't comment on that.
            Lastly, being a caravan owner, I use a weight distribution hitch. I have been told that Treg's chew out the neoprene block if used with a weight distribution hitch.
            Dune D4D GXL, ARB bar & racks, Kings/Bilsteins, diff & g'box breathers, underbody protection, air comp, brake controller, Garmin Nuvi, Scangauge II, AGM aux battery & RanOx.
              The trailer i hired the other week had an hyland and was dead easy to use and worked well on fraser.
              [b]Rob[/b]
                We have the treg on our Camprite, have never had any problems lining it up.
                Works well off road.
                  We've got a Treg on our Coromal Van. It's a pain in the arse to line up solo, but once connected, works well.
                  I've heard the Hyland is a very good bit of gear though.
                  [i]I remember when sex was safe, and flying was dangerous![/i]
                    Re: Off Road Trailer couplings Hyland v AT35 v Tregg
                    I recently purchased a CT at the Brisbane Caravan and camping show in June (Still awaiting the CT due to delay in manufacturing). The hitch I went with is the new big brother to the DO25 hitch, the "DO35" hitch, rated at 3.5T.
                    It makes it a lot easier to line and the trailer hitch to the car as it has two diameters
                    Here are a few links.
                    http://www.caravanworld.com.au/news-...eid/55985.aspx
                    The only other link I could find on the manufacturers site was this,
                    http://www.vehiclecomponents.com.au/...?ContentID=655
                    The CT arrives mid July, so I will let you know how I find it after a few trips.
                    SSSHHHH be very very quiet were huntin wabbits.
                      I've used a Hyland for years on my Camper Trailer with no probs and easy connection, my Supreme Getaway came with a Treg it was quickly changed for a Hyland, Tregs are a bitch to line up, and as mentioned are not compatable with load distribution hitch. There are several versions of Hyland light duty for trailers and heavy duty for Caravans.
                      Getaway Ray 2013 Silver GXL D4D Auto, Brash Imports Sat/Nav, Dual Batteries via Redarc DCBC 1220,Waeco 40Litre,Supreme Getaway Van, Albury/Wodonga 4WD Club Member.
                        I have had my CT out for a few trips since it arrive a few months ago and I must admit that I am really impressed with the DO35 hitch. I find it very simple to operate especially putting lining it up. All I got to do is roughly line it up and lower the jockey wheel and it generally finds the centre. A simple movement with the locking mechanism all it is locked and secure.
                          I've tried most types hitches, I've have now got a DO35 and would never go back to using other types.
                          Leachy
                          EX-Prado Owner
                            Yep, have to agree, i love my DO35 easiest one i have used and very little effort to use safely means the missus can hitch it up herself if required!! :wink:
                            05 GXL TD. Kings and Bilsteins, Sovereign bar, ralley 4000 HID's, Dual Batt's, Glind Shower, Uniden UHF, Tinted windows, shiny valve caps,...;-)
                              I am looking at putting one of the DO35 hitches on my CT, just wondering how much people paid for it.
                              Adrian
                              2004 GXL TD 3.0 ARB deluxe bar, Warn winch, IPF Driving lights, Pirhana Dual Battery, Pirhana Dual Battery Monitor, GME UHF, ARB air compressor, Custom storage/ fridge slide, ARB roof rack, Safari snorkel, 2" OME suspension lift, Mickey Thompson MTZ
