Ctek Multi XS 15000
  • Ctek Multi XS 15000
    Hi all
    My charger arrived in the mail today. I was under the impression it came with direct battery connection. I believe you can buy separately but how does it connect? Do you unscrew the back of the charger to remove the existing cable?
    Thx
    Re: Ctek Multi XS 15000
    Just checked google and apparently the 15a only comes with alligator clamps as it has a temp sensor mounted on the positive lead.
    I suppose I could cut the clamps off and affix proper fittings for direct battery connection, but the clip would have to be able to take the temp sensor.
    Has anyone else have a 15 connected direct to battery? If so, how have you mounted the temp sensor?
