Carrying bikes - Hitch or Spare mount?
  • Carrying bikes - Hitch or Spare mount?
    Howdy,
    I have read a few posts on this, and a lot seem to like the Thule Ridgeline (single post - 5 bikes). I did read a post at ExplorOz saying that if you go 4wd and want to take bikes, the best was to get a Hitch mounted, A shaped carrier for extra strength and support.
    Question is, what are most people out there using? And do they go offroad with the bikes? I want a rigid, strong solution, but don't REALLY want to put the rear platform option due to exit clearance etc.
    I am only looking at 2-3 bikes.
    Any suggestions?
    Nick
    Re: Carrying bikes - Hitch or Spare mount?
    http://isi-carriers.com/
      We have one of the old style ones with the twin metal pipes in an inverted "V" - cost about $100
      bit like this :
      http://stanfred.com.au/BC3T.htm
      This goes on the standard hitch and folds down.
      I needed a slighty longer hitch insert ( avaialble for Hayman Reese hitches - not sure about the Toyota ones ) and with this it will clear the spare wheel. I notice Stanfred also make an extended base plate for this purpose.
      http://stanfred.com.au/BP4X4.htm
      The rack is basic but very strong and I'm confident taking it on rough roads with the bikes on the back . Some of these newer and more expensive plasticky ones look great but a little flimsy, I have to say.
      As for mounting on the spare wheel - I would be very reluctant as there's a rick of causing damage to your rear door due to the extra weight and leverage effect of two to three bikes hanging out there. ( ulness they're all carbon fibre bikes )
      Cheers, Wayne
        I like the look of the ISI ones.... but where can I buy it from? Have done a search with no luck!
          Contact them directly http://isi-carriers.com/contact.html
            I use "Thule Spare Me" carrier.
            http://www.thule.com.au/images/product_ ... ounted.pdf
            Mounts on spare wheel, carries 2 bikes.
            Whole thing including bikes moves with the door, so easy acces to back of car.
            But wouldn't use it off road. More to do with the expensive bikes I carry....
            Ex 1988 Mitsubishi Pajero V6
            Ex 1986 Suzuki Sierra
              In my opinion neither
              I have tried them both and here is the issues
              Spare mount to heavy on the door
              Hitch mount you have to unload to get into the back door and even with the swing down ones you are still tripping over bikes.
              Swingaway ones are good but i have not one lotto latley
              The way i have went is on the roof with the ones you take the front wheel off if we are overnighting we just leave em up there. If it is really extreme i have quick release skewers front and back so i can take them apart and throw in the back if i have to.
              Racks are great overhead clearance the only issue and i use a little side step to ge them up there
              Dont list all ya mods, you will only be more upset when i get further
                OK, have finally done plenty of research and have come down to the following:
                Rhino Swagman (http://www.rhinorack.com.au/AccSubCateg ... 48_11.aspx) and
                Thule Roadway (934XT), http://thule.com.au/images/product_deta ... rriers.pdf
                ISI is just a little too expensive for me, and these carry 4 bikes. Roof mounted will not work as have a cage on the roof with luggage (kids take a LOT of stuff). These two have 2 separate contact points with the bikes and hence place less stress on the frame over long distances.
                My question, does anyone out there use either of these two? And if so, what are your thoughts?
                THANKS HEAPS!
                Nick.
                  I don't think either will fit because of the door mounted spare. The Rhino website says that it has 195mm of clearance between the hole in the hitch mount and the vertical bar. Prado tyre widths are 245 or 265mm.
                    I use the Thule BA934XT. It works well. It can be a pain if you want to open the back door when the bikes are on. A couple of other disadvantages (only if leaving the tarmac) of this are the change of departure angle and the risk of the bikes getting covered in dust when driving on gravel roads. Other than this, I'm really happy with it.
                    I have a Thule roof mounted bike carrier too. This never gets used because it is too much of a pain getting the bike up there.
