have priced exhaust jacks on ebay , they seem the same as the genuine ones"bushranger etc" but are almost half price. Has anyone bought a cheap one . Any feed back on exhaust jacks in general would be great. mal56
exhaust jacks
exhaust jacks
2008 gxl d4d with safety pack, traction control ,down hill assist,arb bullbar,ome suspension and lift kit,arb dual batteries,cooper stts,gme 3440 uhf,waco50lt,iph 900 xs driving lights,black widow draws and fridge slide.scan gauge 11,tow bar, terrian tamer winch with dynamic rope,arb onboard compresor,tvan murranji mark 3 camper trailerTags: None
Re: exhaust jacks
I imagine they're cheaper because of the material. The construction is pretty basic so there's no real better or worse in that sense.
I could see cheaper material getting tears/holes in it a lot easier.
Out of interest what prices are they both going for?<Rob> '12 Prado GX - https://www.pradopoint.com.au/forum/general/my-rig-build-up/32702-i-m-back-with-a-2012-150-gx-toorak-tractor
Re: exhaust jacks
Do they lock in the gas? Or will they deflate once you remove the pipe from the exhaust or turn off the motor? A good one should allow you to control the deflation rate or hold it in place. It should also have good quality protection mats that won't melt against the exhaust pipe. Check also the length of the pipe and the capacity of the bag.
There's some good ones and then there are some really poor models.Dave
Re: exhaust jacks
We bought a cheapie from KMart about $100 tested it in the garage to make sure it was ok, worked alright, it held pressure lifted the 90 serries easily but with a 40mm suspension lift it didn't have enough height to lift the wheel off the ground so we took it back thought it wasn't much use if you could not lift the wheel high enough to get a log or something under it. So make sure you get a good height jack.2001 3Lt Manual Diesel, Safari Snorkel, ARB Winch Bullbar, Hella Spotlights, 9000lb Warn Winch, Dual Battery, Couplertec Electronic Rust Prevention, Glind Hot Water Shower, ARB Front and Rear Air Lockers,Onboard Air Compressor, DP Chip, 40mm OME Lift, Steel Slider Side Steps, GME 3200 CB Radio, Milford Cargo Barrier, Extended Diff Breathers, Draw system and Fridge Slide, 40lt Engel Fridge, GPS with Wireless Reversing Camera, Rhino Roof Racks with Aluminium Tray, Awning and Drop down Table on Rear Door.
Re: exhaust jacks
I have an Extra-Large Bushranger bag - about mid-range price, but I can't remember exactly what I paid for it now.
The gas is locked in until the hose is removed. You can regulate the amount that is removed by carefully unlocking the pipe, letting some gas out and relocking. It also comes with two good quality mats for top and bottom protection, though I also carry a carpet off-cut for added protection. The most difficult thing for me is adjusting the bag so that as it lifts, it doesn't come into contact with the side-step saddles, which are relatively sharp.
I've used mine a couple of times on my 2" lifted (with MickyT 265/70 ATZ) and it worked as advertised. I've also used it on other lifted Prados in the desert for a quick repair job. I don't leave for a 4WD trip without it.
I had a Youtube video that was taken down - they didn't like that I used an AC/DC song as background music. I must try and put that back up again.
LFaR.[size=1][color=#770000]29Feb12:[/color][color=#777700]12GXLTD Auto, ARB Deluxe Winch bar, WARN 9.5xp Winch, IPF 900XS, Tow, Safari snorkel, Front + Rear Recovery points, ARB OME NC Sports, ATZ-4Rib[/color][color=grey], Silver[/color]. [color=orange][b]MaxTrax[/b][/color], [color=maroon]ScanGuage II[/color], [color=blue]ARB CKMA12[/color], [color=deeppink]UHF: GME TX3440 AE4018K1 UNH047SX[/color], [color=darkgreen]Bushranger Air Jack[/color], [color=green]Staun + ARB Deflators[/color], [color=brown]WindCheetah Roof Rack[/color], [color=green]Foxwing[/color], [color=red]Super Charge MRV70, Redarc BCDC1220[/color], [color=darkblue]ARB 60L fridge[/color], [color=blue]MSA Fridge Dropdown slide[/color], [color=darkyellow]DRIFTA Drawers[/color], [color=gold]TJM Bash Plates[/color], [color=brown]TG150[/color].[/size]
Re: exhaust jacks
thanks guys, from reading the specs they seem the same thickness, and come with mats or carpet, 6 m of hose and are able to be inflated with a compressor as well. I dont know if you can lock off and deflate.cost around $115 so are 1/3 of the bushranger. mal562008 gxl d4d with safety pack, traction control ,down hill assist,arb bullbar,ome suspension and lift kit,arb dual batteries,cooper stts,gme 3440 uhf,waco50lt,iph 900 xs driving lights,black widow draws and fridge slide.scan gauge 11,tow bar, terrian tamer winch with dynamic rope,arb onboard compresor,tvan murranji mark 3 camper trailer
Re: exhaust jacks
Originally posted by mal56... and are able to be inflated with a compressor as well.
