Hi guys, I recently bought a Prado Snowy 1999, previous owner had installed a dual battery, and there is a power point inside the back of the car, I want to get a fride to plug in, but I am struggling to identify what kind of plug it is. Can anyone please help me? Cheers
Weird dual battery system plug. Need help.
Originally posted by TrapperWill View PostHi guys, I recently bought a Prado Snowy 1999, previous owner had installed a dual battery, and there is a power point inside the back of the car, I want to get a fride to plug in, but I am struggling to identify what kind of plug it is. Can anyone please help me? Cheers
Be careful as NSW and Vic standards were reversed.
Available atJaycar http://www.jaycar.com.au/2-pin-32-vo...-plug/p/PP2075
Most of mine have been replaced with Anderson plugs or powerpoles.
S.155 SX with dual battery and Polyairs in the rear springs..
- 1 like
As above low volt dc 12 volt... I have a Trailblaza freezer that runs 240/12 volt system and that’s the kind of plug it uses. They are not the cheapest option.. I think I paid $15 just for one end of the plug can’t recall which but it was 5he more expensive of th3 two.. personally I’d b3 swapping it for a flush mounted Anderson plus... less chance of it coming dislodged in transit2018 VX Prado
- 1 like
Originally posted by Pradosaur View PostAs above low volt dc 12 volt... I have a Trailblaza freezer that runs 240/12 volt system and that’s the kind of plug it uses. They are not the cheapest option.. I think I paid $15 just for one end of the plug can’t recall which but it was 5he more expensive of th3 two.. personally I’d b3 swapping it for a flush mounted Anderson plus... less chance of it coming dislodged in transit
Cheers.
In my experience the vertical pin is negative but it could be either. Use a multimeter to find out. Also these have a habit of moving with vibration and causing arcing. I would change it for an Anderson plug or Anderson powerpoles. Genuine variety.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
- 1 like
Thanks for the reply. I would also like to ask that do you know which pin is for the LIVE WIRE and which pin is for the NEUTRAL WIRE? I want to wire my USB sockets onto it. Do you think is safe to do so?
Cheers.2018 VX Prado
- 1 like
