Draws
  • Draws
    Hi anyone able to advise please , I have a 150 Prado with the 7 seats that fold flat so I loose a bit of room in height.
    was wondering if anyone would know if you could fit a set of Titan double draws in the rear then mount a kings 60 litre fridge on top and still have enough height / clearance for the fridge to slide out as I dont want to have remove the 3 row seats if possible.
    plus fitting suggestions, if you do have enough Height as i have never installed draws before and to make ease of install / removal would just using the 4 anchor points be enough to hold a double set of draws in place in lieu of installing a base and fixing the draws too , again to allow ease of install and removal , cheers
    If I were you I'd measure it out with a tape- Get the height of what you have now from your seats to roof and then add the height of a set of drawers and fridge on top of that. My gut feeling would be that it won't fit to be honest. I've got a set of drawers with the seat removed and I can't open the lid of my 40L engle properly (although the lid setup of them is different to the kings ones I if recall correctly.
      When we picked up our 150 I test fitted our NL Weekender fridge in the back and couldnt open the lid. The NL lid opens sideways. As Atherton suggests grab a tape but I would be doubtful it will fit.
          I would think not. As everyone else found out, our Engel 40L lid doesn't open very far with the seats. It wouldn't fit if there were drawers in there.
          There is also no real way to mount the drawers on top of the seats. Besides, get rid of the extra weight. It really is easy to take the seats out, I could do it in less than an hour be myself.
          Cheers, Nova
            Thank u!
            drift boss
