New brake controller issue
  • New brake controller issue
    I have connected a Hayman Reese wiring harness to my car. It is an easy plug in type one and didn't require any splicing.
    When I connect the controller the car, the light turns green for about a second or two. Then it flashes in red.
    It is a brand new Compact IQ controller and wiring harness.
    I have double checked that the power and ground cavles are properly connected.
    The blue cable has connectivity to the trailer plug. The red brake spotlight wire is also connected properly and reads a signal when the brake padle is pressed.
    The manual trailer brake button is also working. All verified with a multimeter.
    I can only think that this is normal behaviour when there is no trailer attached (haven't purchased one yet).
    Or the controller is faulty.
    Any ideas about what the cause is or what I can test?
    Not ever been a fan of the HR ones. Seen a few faults with them over time. Anyway.
    Red flashing as dictated by the brochure page indicates a connection fault. As you say you have not got a trailer connected I suspect you've found the issue.
    Couldn't find a user manual easily online for it, which is another reason I don't like them, why hide user manuals away?! Common sense really.
    Try it with a trailer connected and see what happens.
      Thank you. I called Hayman Reese (Name was Dillon) and he said it was normal behaviour. The light will go off once the trailer is connected.
      Now to find a trailer to see if he is right....
        Mine has been in for 3 years and does the same.The light goes out after a very short time. I recall that the instructions said that this was normal. All is fine when the trailer is connected.
          Thank you. Good to know
