chrisg
  • chrisg
    Hi all
    my November 2013 150 diesel prado has only done 77km, is it worth changing the timing belt at this km, probably selling next year. Any advice would be appreciated.
    Regards, Chris
    Probably. Materials degrade over time regardless of use.
      Presume you mean 77,000 km. I wouldn't be changing anything with just 77kms on the clock!
      If there is nothing wrong with the motor then you'll never recoup any money you throw at it. If you already have to take the engine apart then it may be worthwhile.
        We will assume you mean 73,100 miles. With only 77 kilometers on the odometer, I wouldn't touch a thing!
        Your investment in fixing the motor might be fruitless if the problem isn't there. Since you'll need to disassemble the engine anyway, it could be a good idea to do this. basketball stars
          If the issue isn't present, your investment in repairing the motor can be in vain. This may be an excellent option as you'll have to disassemble the engine anyhow.
