What OBD Mode 01 PIDs does your vehicle support and how to access them on a Scangauge - Part 1
  • What OBD Mode 01 PIDs does your vehicle support and how to access them on a Scangauge - Part 1
    This is a pretty comprehensive list of standard OBDII Service 01 PIDs with matching SGII X-Guage Codes (its a work in progress so not fully populated and also may have some X-Gauge coding errors as due to the number of PIDs I haven't validated all of them).
    The links at the bottom of the table contain the source for most of the PID info and can be used to get additional info or assist decode many of them if needed.
    How can you use this info?
    Link to SGII user guide if needed: https://www.scangauge.com.au/assets/files/SGII-UM-601.pdf
    To know what OBDII Service 01 codes your vehicle supports, on a SGII access the Custom Command feature, enter command 0100 and write down what response you get when you press Send.
    Repeat for 0120, 0140, 0160, 0180, 01A0, 01C0 (not all will generate a response on some vehicles).
    Open this link (OBD2 PID Overview [Lookup/Converter Tool, Table, CSV, DBC] – CSS Electronics) which contains a decoding function and select PID 00 in the dropdown list at the top left and enter the value you wrote for 0100 into the value boxes.
    You should then see at the bottom what PIDs in the range 01-20 your vehicle supports via a Yes/No.
    Repeat for the other PID responses 20, 40, 60, 80, A0, C0.
    Once you know what your vehicle supports you can lookup in the spreadsheet and add any relevant parameters that you would like to monitor to you X-Gauge list (assuming you have spare slots left)
    As the SG3 doesn't have the Custom Command feature the x-gauge codes to access the 0100 etc are included in the table but have to be obtained in two steps.
    This list also posted on Scangauge Community FB page in files area if you want to download as an Excel file (as due to size and format I can't post here)
    Hope this is useful to someone
    ODB II Service 01 PIDS SCANGAUGE X-GAUGE CODES
    PID Title Formula Min Max Scaling/Bit Value/Units TXD RXF RXD MTH Name Notes
    00 Supported PIDS (01-20) Hex -Bit encoded n/a n/a n/a 07DF0100 044115000000 2810 / 3810 000100010000 Output is in Hex - From web resource decode meaning of each RXD set - 2810 is for AB bits 7-0 / 3810 is for CD bits 7-0
    01 Monitor status since DTCs cleared Hex -Bit encoded n/a n/a n/a 07DF0101 044115010000 2810 / 3810 000100010000 Output is in Hex - From web resource decode meaning of each RXD set - 2810 is for AB bits 7-0 / 3810 is for CD bits 7-0
    02 DTC that caused required freeze frame data storage Hex -Bit encoded n/a n/a n/a 07DF0102 044115020000 2810 000100010000 Output is in Hex - From web resource decode meaning of AB bits 7-0
    03 Fuel system status Hex -Bit encoded n/a n/a n/a 07DF0103 044115030000 2810 000100010000 Output is in Hex - From web resource decode meaning of AB bits 7-0
    04 Calculated engine load A*100/255 0 100 100/255 % 07DF0104 044105040000 2808 006400FF0000 LOD
    05 Engine coolant temperature A-40 -40 215 1 Deg C 07DF0105 044105050000 2808 00010001FFD8 CWT
    06 Short term fuel trim (banks 1 and 3) A/1.28-100 -100 99 0.78 % 07DF0106 044105060000 2808 00640080FF9C
    07 Long term fuel trim (banks 1 and 3) A/1.28-100 -100 99 0.78 % 07DF0107 044105070000 2808 00640080FF9C
    08 Short term fuel trim (banks 2 and 4) A/1.28-100 -100 99 0.78 % 07DF0108 044105080000 2808 00640080FF9C
    09 Long term fuel trim (banks 2 and 4) A/1.28-100 -100 99 0.78 % 07DF0109 044105090000 2808 00640080FF9C
    0A Fuel pressure (gauge) A*3 0 765 3 kPa 07DF010A 0441050A0000 2808 000300010000
    0B Intake manifold absolute pressure A 0 255 1 kPa 07DF010B 0441050B0000 2808 000100010000
    0C Engine speed (256*A+B)/4 0 16384 1/4 RPM 07DF010C 0441050C0000 2810 000100040000 RPM
    0D Vehicle speed A 0 255 1 km/h 07DF010D 0441050D0000 2808 000100010000 KMH
    0E Ignition timing advance for #1 cylinder A/2-64 -64 64 0.5 deg 07DF010E 0441050E0000 2808 00010002FFC0
    0F Intake air temperature A-40 -40 215 1 Deg C 07DF010F 0441050F0000 2808 00010001FFD8 IAT
    10 MAF air flow rate (256*A+B)/100 0 655 1/100 g/s 07DF0110 044105100000 2810 000100640000 MAF
    11 Absolute throttle position A/2.55 0 100 0.39 % 07DF0111 044105110000 2808 006400FF0000 TP
    12 Commanded secondary air status Hex -Bit encoded n/a n/a n/a 07DF0112 044115120000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    13 Location of oxygen sensors (up to 2 banks) Hex -Bit encoded n/a n/a n/a 07DF0113 044115130000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    14 Oxygen sensor (narrowband) bank 1 sensor 1 A/200 0 1 0.005 V 07DF0114 044105140000 2808 000100C80000
    15 Oxygen sensor (narrowband) bank 1 sensor 2 A/200 0 1 0.005 V 07DF0115 044105150000 2808 000100C80000
    16 Oxygen sensor (narrowband) bank 1 sensor 3 A/200 0 1 0.005 V 07DF0116 044105160000 2808 000100C80000
    17 Oxygen sensor (narrowband) bank 1 sensor 4 A/200 0 1 0.005 V 07DF0117 044105170000 2808 000100C80000
    18 Oxygen sensor (narrowband) bank 2 sensor 1 A/200 0 1 0.005 V 07DF0118 044105180000 2808 000100C80000
    19 Oxygen sensor (narrowband) bank 2 sensor 2 A/200 0 1 0.005 V 07DF0119 044105190000 2808 000100C80000
    1A Oxygen sensor (narrowband) bank 2 sensor 3 A/200 0 1 0.005 V 07DF011A 0441051A0000 2808 000100C80000
    1B Oxygen sensor (narrowband) bank 2 sensor 4 A/200 0 1 0.005 V 07DF011B 0441051B0000 2808 000100C80000
    1C OBD requirements to which vehicle or engine is certified Hex -Bit encoded n/a n/a n/a 07DF011C 0441151C0000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    1D Location of oxygen sensors (up to 4 banks) Hex -Bit encoded n/a n/a n/a 07DF011D 0441151D0000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    1E Auxiliary input status Hex -Bit encoded n/a n/a n/a 07DF011E 0441151E0000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    1F Run time since engine start 256*A+B 0 65535 1 seconds 07DF011F 0441051F0000 2810 000100010000
    20 Supported PIDS (21-40) Hex -Bit encoded n/a n/a n/a 07DF0120 044115200000 2810 / 3810 000100010000 Output is in Hex - From web resource decode meaning of each RXD set - 2810 is for AB bits 7-0 / 3810 is for CD bits 7-0
    21 Distance traveled with malfunction indicator lamp (MIL) on 256*A+B 0 65535 1 km 07DF0121 044105210000 2810 000100010000
    22 Fuel rail pressure relative to manifold vacuum (256*A+B)/12.8 0 5177 0.079 kPa 07DF0122 044105220000 2810 000A00800000
    23 Fuel rail pressure (256*A+B)*10 0 655350 10 kPa 07DF0123 044105230000 2810 000A00010000
    24 Oxygen sensor (wideband) bank 1 sensor 1 (256*A+B)/32768 0 2 0.00003 ratio 07DF0124 044145240000 2810 006480000000
    25 Oxygen sensor (wideband) bank 1 sensor 2 (256*A+B)/32768 0 2 0.00003 ratio 07DF0125 044145250000 2810 006480000000
    26 Oxygen sensor (wideband) bank 1 sensor 3 (256*A+B)/32768 0 2 0.00003 ratio 07DF0126 044145260000 2810 006480000000
    27 Oxygen sensor (wideband) bank 1 sensor 4 (256*A+B)/32768 0 2 0.00003 ratio 07DF0127 044145270000 2810 006480000000
    28 Oxygen sensor (wideband) bank 2 sensor 1 (256*A+B)/32768 0 2 0.00003 ratio 07DF0128 044145280000 2810 006480000000
    29 Oxygen sensor (wideband) bank 2 sensor 2 (256*A+B)/32768 0 2 0.00003 ratio 07DF0129 044145290000 2810 006480000000
    2A Oxygen sensor (wideband) bank 2 sensor 3 (256*A+B)/32768 0 2 0.00003 ratio 07DF012A 0441452A0000 2810 006480000000
    2B Oxygen sensor (wideband) bank 2 sensor 4 (256*A+B)/32768 0 2 0.00003 ratio 07DF012B 0441452B0000 2810 006480000000
    2C Commanded EGR A/2.55 0 100 0.39 % 07DF012C 0441052C0000 2808 006400FF0000
    2D EGR Error A/1.28-100 -100 99 0.78 % 07DF012D 0441052D0000 2808 00640080FF9C
    2E Commanded Evaporative Purge A/2.55 0 100 0.39 % 07DF012E 0441052E0000 2808 006400FF0000
    2F Fuel Level Input A/2.55 0 100 0.39 % 07DF012F 0441052F0000 2808 006400FF0000
    30 Warm-ups since codes cleared A 0 255 1 count 07DF0130 044105300000 2808 000100010000
    31 Distance travelled since codes cleared 256*A+B 0 65535 1 km 07DF0131 044105310000 2810 000100010000
    32 Evap System Vapor Pressure (256*A+B)/4 0 16384 0.25 Pa 07DF0132 044105320000 2810 000100040000
    33 Absolute Barometric Pressure A 0 255 1 kPa 07DF0133 044185330000 2808 006400450000 BP
    34 Oxygen sensor (wideband) bank 1 sensor 1 (256*A+B)/32768 0 2 0.00003 ratio 07DF0134 044145340000 2810 006480000000
    35 Oxygen sensor (wideband) bank 1 sensor 2 (256*A+B)/32768 0 2 0.00003 ratio 07DF0135 044145350000 2810 006480000000
    36 Oxygen sensor (wideband) bank 1 sensor 3 (256*A+B)/32768 0 2 0.00003 ratio 07DF0136 044145360000 2810 006480000000
    37 Oxygen sensor (wideband) bank 1 sensor 4 (256*A+B)/32768 0 2 0.00003 ratio 07DF0137 044145370000 2810 006480000000
    38 Oxygen sensor (wideband) bank 2 sensor 1 (256*A+B)/32768 0 2 0.00003 ratio 07DF0138 044145380000 2810 006480000000
    39 Oxygen sensor (wideband) bank 2 sensor 2 (256*A+B)/32768 0 2 0.00003 ratio 07DF0139 044145390000 2810 006480000000
    3A Oxygen sensor (wideband) bank 2 sensor 3 (256*A+B)/32768 0 2 0.00003 ratio 07DF013A 0441453A0000 2810 006480000000
    3B Oxygen sensor (wideband) bank 2 sensor 4 (256*A+B)/32768 0 2 0.00003 ratio 07DF013B 0441453B0000 2810 006480000000
    3C Catalyst Temperature Bank 1, Sensor 1 (256*A+B)/10-40 -40 6514 0.1 Deg C 07DF013C 0441453C0000 2810 0001000AFFD8
    3D Catalyst Temperature Bank 2, Sensor 1 (256*A+B)/10-40 -40 6514 0.1 Deg C 07DF013D 0441453D0000 2810 0001000AFFD8
    3E Catalyst Temperature Bank 1, Sensor 2 (256*A+B)/10-40 -40 6514 0.1 Deg C 07DF013E 0441453E0000 2810 0001000AFFD8
    3F Catalyst Temperature Bank 2, Sensor 2 (256*A+B)/10-40 -40 6514 0.1 Deg C 07DF013F 0441453F0000 2810 0001000AFFD8
    40 Supported PIDS (41-60) Hex -Bit encoded n/a n/a n/a 07DF0140 044115400000 2810 / 3810 000100010000 Output is in Hex - From web resource decode meaning of each RXD set - 2810 is for AB bits 7-0 / 3810 is for CD bits 7-0
    41 Monitor status this driving cycle Hex -Bit encoded n/a n/a n/a 07DF0141 044115410000 2810 / 3810 000100010000 Output is in Hex - From web resource decode meaning of each RXD set - 2810 is for AB bits 7-0 / 3810 is for CD bits 7-0
    42 Control module voltage (256*A+B)/1000 0 66 0.001 Volts 07DF0142 044185420000 2810 000100640000 VLT
    43 Absolute Load Value (256*A+B)/2.55 0 25700 0.39 % 07DF0143 044105430000 2810 006400FF0000
    44 Fuel/Air Commanded Equivalence Ratio (256*A+B)/32768 0 2 0.00003 ratio 07DF0144 044145440000 2810 006480000000
    45 Relative Throttle Position A/2.55 0 100 0.39 % 07DF0145 044105450000 2808 006400FF0000
    46 Ambient air temperature A-40 -40 215 1 Deg C 07DF0146 044105460000 2808 00010001FFD8 AIR
    47 Absolute Throttle Position B A/2.55 0 100 0.39 % 07DF0147 044105470000 2808 006400FF0000
    48 Absolute Throttle Position C A/2.55 0 100 0.39 % 07DF0148 044105480000 2808 006400FF0000
    49 Accelerator pedal position D A/2.55 0 100 0.39 % 07DF0149 044105490000 2808 006400FF0000
    4A Accelerator pedal position E A/2.55 0 100 0.39 % 07DF014A 0441054A0000 2808 006400FF0000
    4B Absolute Throttle Position F A/2.55 0 100 0.39 % 07DF014B 0441054B0000 2808 006400FF0000
    4C Commanded Throttle Actuator Control A/2.55 0 100 0.39 % 07DF014C 0441054C0000 2808 006400FF0000
    4D Time run with MIL on 256*A+B 0 65535 1 minutes 07DF014D 0441054D0000 2810 000100010000
    4E Time since trouble codes cleared 256*A+B 0 65535 1 minutes 07DF014E 0441054E0000 2810 000100010000
    4F Max fuel-air equiv.ratio A 0 255 1 ratio 07DF014F 0441054F0000 2808 000100010000
    50 Max air flow ratio from MAF sensor A*10 0 2550 10 g/s 07DF0150 044105500000 2808 000A00010000
    51 Fuel Type Hex -Bit encoded n/a n/a n/a 07DF0151 044115510000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    52 Alcohol Fuel Percentage A/2.55 0 100 0.39 % 07DF0152 044105520000 2808 006400FF0000
    53 Absolute Evap System Vapor Pressure (256*A+B)/200 0 328 0.005 kPa 07DF0153 044105530000 2810 000100C80000
    54 Evap System Vapor Pressure (256*A+B)-32767 -32767 32768 1 Pa 07DF0154 044105540000 2810 000100018001
    55 Short Term Secondary O2 Sensor Fuel Trim Banks 1 and 3 A/1.28-100 -100 99 0.78 % 07DF0155 044105550000 2808 00640080FF9C
    56 Long Term Secondary O2 Sensor Fuel Trim Banks 1 and 3 A/1.28-100 -100 99 0.78 % 07DF0156 044105560000 2808 00640080FF9C
    57 Short Term Secondary O2 Sensor Fuel Trim Banks 2 and 4 A/1.28-100 -100 99 0.78 % 07DF0157 044105570000 2808 00640080FF9C
    58 Long Term Secondary O2 Sensor Fuel Trim Banks 2 and 4 A/1.28-100 -100 99 0.78 % 07DF0158 044105580000 2808 00640080FF9C
    59 Fuel Rail Pressure (absolute) (256*A+B)*10 0 655350 10 kPa 07DF0159 044105590000 2810 000A00010000
    5A Relative Accelerator Pedal Position A/2.55 0 100 0.39 % 07DF015A 0441055A0000 2808 006400FF0000
    5B Hybrid/EV Battery Pack Remaining Charge A/2.55 0 100 0.39 % 07DF015B 0441055B0000 2808 006400FF0000
    5C Engine Oil Temperature A-40 -40 215 1 Deg C 07DF015C 0441055C0000 2808 00010001FFD8
    5D Fuel injection timing ((256*A+B)/128)-210 -210 302 1/128 degrees 07DF015D 0441055D0000 2810 00010080FF2E FIT
    5E Engine Fuel Rate (256*A+B)/20 0 3277 0.05 L/h 07DF015E 0441055E0000 2810 000100140000
    5F Emission requirements to which vehicle is designed Hex -Bit encoded n/a n/a n/a 07DF015F 0441155F0000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    See Part 2 for remainder of list as it was too big to post in single table due to limit on number of characters
    ptommo59
