What OBD Mode 01 PIDs does your vehicle support and how to access them on a Scangauge - Part 2
  • What OBD Mode 01 PIDs does your vehicle support and how to access them on a Scangauge - Part 2
    I had to split the list due to too many characters
    ODB II Service 01 PIDS SCANGAUGE X-GAUGE CODES
    PID Title Formula Min Max Scaling/Bit Value/Units TXD RXF RXD MTH Name Notes
    60 Supported PIDS (61-80) Hex -Bit encoded n/a n/a n/a 07DF0160 044115600000 2810 / 3810 000100010000 Output is in Hex - From web resource decode meaning of each RXD set - 2810 is for AB bits 7-0 / 3810 is for CD bits 7-0
    61 Driver's Demand Engine - Percent Torque A-125 -125 130 1 % 07DF0161 044105610000 2808 00010001FF83
    62 Actual Engine - Percent Torque A-125 -125 130 1 % 07DF0162 044105620000 2808 00010001FF83
    63 Engine Reference Torque 256*A+B 0 65535 1 Nm 07DF0163 044105630000 2810 000100010000
    64 Engine Percent Torque (idle) A-125 -125 130 1 % 07DF0164 044105640000 2808 00010001FF83
    65 Auxiliary input / output supported A - bit encoded n/a n/a n/a 07DF0165 044115650000 2810 000100010000 Output is in Hex - From web resource decode meaning of AB bits 7-0
    66 Mass Air Flow Sensor (256*A+B)/32 0 2048 0.03 g/s 07DF0166 044105660000 2810 000100200000
    67 Engine Coolant Temperature A - bit encoded n/a n/a n/a Bit 0 - Temp 1 supported
    Bit 1 - Temp 2 supported
    07DF0167 044115670000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    67 Engine Coolant Temperature 1 B-40 -40 215 1 Deg C 07DF0167 044105670000 3008 00010001FFD8
    67 Engine Coolant Temperature 2 C-40 -40 215 1 Deg C 07DF0167 044105670000 3808 00010001FFD8
    68 Intake Air Temperature Sensor A - bit encoded n/a n/a n/a 07DF0168 054116680000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    69 Actual EGR, Commanded EGR, and EGR Error A - bit encoded n/a n/a n/a 07DF0169 054116690000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    69 Commanded EGR A Duty Cycle/Position B/2.55 0 100 0.39 % 07DF0169 054116690000 3808 006400FF0000 CEG
    69 Actual EGR A Duty Cycle/Position C/2.55 0 100 0.39 % 07DF0169 054116690000 4008 006400FF0000 AEG
    69 EGR A Error D/1.28-100 -100 99 0.78 % 07DF0169 054116690000 4808 00640080FF9C EEG
    6A Commanded Diesel intake air flow control and relative intake air flow position A - bit encoded n/a n/a n/a 07DF016A 0441156A0000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    6A Commanded Intake Air Flow A Control B/2.55 0 100 0.39 % 07DF016A 0441056A0000 3008 006400FF0000 CAF
    6A Relative Intake Air Flow A Position C/2.55 0 100 0.39 % 07DF016A 0441056A0000 3808 006400FF0000 IAF
    6B Exhaust Gas Recirculation Temperature A - bit encoded n/a n/a n/a 07DF016B 0441156B0000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    6C Commanded Throttle Actuator Control and Relative Throttle Position A - bit encoded n/a n/a n/a 07DF016C 0441156C0000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    6D Fuel pressure control system A - bit encoded n/a n/a n/a 07DF016D 0541166D0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    6D Commanded Fuel Rail Pressure A (256 * B + C) * 10 0 655350 10 kPa 07DF016D 0541066D0000 3810 000100640000 CFA Due to SGII 4 digit limit adjusted scaling to read in MPa
    6D Fuel Rail Pressure A (256 * D + E) * 10 0 655350 10 kPa 07DF016D 0541066D0000 4810 000100640000 AFA Due to SGII 4 digit limit adjusted scaling to read in MPa
    6D Commanded Fuel Rail Pressure B (256 * G + H) * 10 0 655350 10 kPa 07DF016D 032100000000 3010 000100640000 CFB Due to SGII 4 digit limit adjusted scaling to read in MPa
    6D Fuel Rail Pressure B (256 * I + J) * 10 0 655350 10 kPa 07DF016D 032100000000 4010 000100640000 AFB Due to SGII 4 digit limit adjusted scaling to read in MPa
    6E Injection Pressure Control System A - bit encoded n/a n/a n/a 07DF016E 0541166E0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    6F Turbocharger Compressor Inlet Pressure A - bit encoded n/a n/a n/a 07DF016F 0541166F0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    70 Boost pressure control A - bit encoded n/a n/a n/a 07DF0170 054116700000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    70 Commanded Boost Pressure A (256 * B + C) / 32 0 2048 0.03125 kPa 07DF0170 054106700000 3810 000100200000 BSC
    71 Variable Geometry Turbo (VGT) control A - bit encoded n/a n/a n/a 07DF0171 054116710000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    71 Commanded VGT A Position B/2.55 0 100 0.39 % 07DF0171 054106710000 3808 006400FF0000 CVP
    71 VGT A Position C/2.55 0 100 0.39 % 07DF0171 054106710000 4008 006400FF0000 VGT
    72 Wastegate Control A - bit encoded n/a n/a n/a 07DF0172 044115720000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    73 Exhaust Pressure A - bit encoded n/a n/a n/a 07DF0173 044115730000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    74 Turbocharger RPM A - bit encoded n/a n/a n/a 07DF0174 044115740000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    75 Turbocharger A Temperature A - bit encoded n/a n/a n/a 07DF0175 054116750000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    76 Turbocharger B Temperature A - bit encoded n/a n/a n/a 07DF0176 054116760000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    77 Charge air cooler temperature A - bit encoded n/a n/a n/a 07DF0177 044115770000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    77 CACT Bank 1, Sensor 1 B - 40 -40 215 1 Deg C 07DF0177 044105770000 3008 00010001FFD8 CAC
    78 EGT Bank 1 (sensors 1 to 4) A - bit encoded n/a n/a n/a Bit 0 - B1S1 supported
    Bit 1 - B1S2 supported
    Bit 2 - B1S3 supported
    Bit 3 - B1S4 supported
    07DF0178 054116780000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    78 EGT Bank 1, Sensor 1 ((256 * B + C) / 10) - 40 -40 6513.5 0.1 Deg C 07DF0178 054106780000 3810 0001000AFFD8 ET1
    78 EGT Bank 1, Sensor 2 ((256 * D + E) / 10) - 40 -40 6513.5 0.1 Deg C 07DF0178 054106780000 4810 0001000AFFD8 ET2
    78 EGT Bank 1, Sensor 3 ((256 * F + G) / 10) - 40 -40 6513.5 0.1 Deg C 07DF0178 032100000000 2010 0001000AFFD8 ET3
    78 EGT Bank 1, Sensor 4 ((256 * H + I) / 10) - 40 -40 6513.5 0.1 Deg C 07DF0178 032100000000 3010 0001000AFFD8 ET4
    79 EGT Bank 2 (sensors 1 to 4) A - bit encoded n/a n/a n/a Bit 0 - B2S1 supported
    Bit 1 - B2S2 supported
    Bit 2 - B2S3 supported
    Bit 3 - B2S4 supported
    07DF0179 054116790000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    78 EGT Bank 2, Sensor 1 ((256 * B + C) / 10) - 40 -40 6513.5 0.1 Deg C 07DF0179 054106790000 3810 0001000AFFD8 ET5
    78 EGT Bank 2, Sensor 2 ((256 * D + E) / 10) - 40 -40 6513.5 0.1 Deg C 07DF0179 054106790000 4810 0001000AFFD8 ET6
    78 EGT Bank 2, Sensor 3 ((256 * F + G) / 10) - 40 -40 6513.5 0.1 Deg C 07DF0179 032100000000 2010 0001000AFFD8 ET7
    78 EGT Bank 2, Sensor 4 ((256 * H + I) / 10) - 40 -40 6513.5 0.1 Deg C 07DF0179 032100000000 3010 0001000AFFD8 ET8
    7A Diesel Particulate Filter (DPF) Bank 1 A - bit encoded n/a n/a n/a 07DF017A 0541167A0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    7A DPF Bank 1 Delta Pressure (256 * B + C) / 100 (two's complement signed) -328 328 0.01 kPa 07DF017A 0541467A0000 3810 000100010000 DPD
    7B Diesel Particulate Filter (DPF) Bank 2 A - bit encoded n/a n/a n/a 07DF017B 0541167B0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    7C Diesel Particulate Filter (DPF) Temperature A - bit encoded n/a n/a n/a 07DF017C 0541167C0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    7D NOx NTE control area status A - bit encoded n/a n/a n/a 07DF017D 0441157D0000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    7E PM NTE control area status A - bit encoded n/a n/a n/a 07DF017E 0441157E0000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    7F Engine Run Time A - bit encoded n/a n/a n/a 07DF017F 0541167F0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    80 Supported PIDS (81-A0) Hex -Bit encoded n/a n/a n/a 07DF0180 044115800000 2810 / 3810 000100010000 Output is in Hex - From web resource decode meaning of each RXD set - 2810 is for AB bits 7-0 / 3810 is for CD bits 7-0
    81 Engine Run Time for AECD #1 - #5 A - bit encoded n/a n/a n/a 07DF0181 054116810000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    82 Engine Run Time for AECD #6 - #10 A - bit encoded n/a n/a n/a 07DF0182 054116820000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    83 NOx Sensor A - bit encoded n/a n/a n/a 07DF0183 054116830000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    84 Intake Manifold Surface Temperature A-40 -40 215 1 Deg C 07DF0184 044105840000 2808 00010001FFD8
    85 NOx Control System A - bit encoded n/a n/a n/a 07DF0185 054116850000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    86 Particulate Matter (PM) Sensor A - bit encoded n/a n/a n/a 07DF0186 044115860000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    87 Intake manifold absolute pressure A - bit encoded n/a n/a n/a 07DF0187 044115870000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    87 Intake Manifold Absolute Pressure A (256 * B + C) / 32 0 2048 0.03125 kPa 07DF0187 044185870000 3010 000C01090000 MAP
    88 SCR inducement system A - bit encoded n/a n/a n/a 07DF0188 054116880000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    89 Engine Run Time for AECD #11 - #15 A - bit encoded n/a n/a n/a 07DF0189 054116890000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    8A Engine Run Time for AECD #16 - #20 A - bit encoded n/a n/a n/a 07DF018A 0541168A0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    8B Diesel Aftertreatment Status AB - bit encoded n/a n/a n/a 07DF018B 0541168B0000 3010 000100010000 Output is in Hex - From web resource decode meaning of AB bits 7-0
    8C O2 Sensor (Wide Range) A - bit encoded n/a n/a n/a 07DF018C 0541168C0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    8C O2 Sensor Lambda Bank 1 Sensor 1 (256 * J + K) * 0.000122 0 7.99 0.000122 Lambda 07DF018C 032140000000 4010 006420040000 O2L
    8D Absolute Throttle Position G A/2.55 0 100 0.39 % 07DF018D 0441058D0000 2808 006400FF0000
    8E Engine Friction - Percent Torque A-125 -125 130 1 % 07DF018E 0441058E0000 2808 00010001FF83
    8F Particulate Matter (PM) Sensor Output A - bit encoded n/a n/a n/a 07DF018F 0541168F0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    90 WWH-OBD Vehicle OBD System Information A - bit encoded n/a n/a n/a 07DF0190 044115900000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    91 WWH-OBD ECU OBD System Information A - bit encoded n/a n/a n/a 07DF0191 044115910000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    92 Fuel System Control Status (Compression Ignition) A - bit encoded n/a n/a n/a 07DF0192 044115920000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    93 WWH-OBD Vehicle OBD Counters A - bit encoded n/a n/a n/a 07DF0193 044115930000 2808 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    94 NOx control - driver inducement system status and counters A - bit encoded n/a n/a n/a 07DF0194 054116940000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    95 Reserved
    96 Reserved
    97 Reserved
    98 EGT Bank 1 (sensors 5 to 8) A - bit encoded n/a n/a n/a 07DF0198 054116980000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    99 EGT Bank 2 (sensors 5 to 8) A - bit encoded n/a n/a n/a 07DF0199 054116990000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    9A Hybrid/EV system data
    9B Diesel exhaust fluid sensor data
    9C O2 Sensor (Wide Range) A - bit encoded n/a n/a n/a 07DF019C 0541169C0000 3008 000100010000 Output is in Hex - From web resource decode meaning of A bits 7-0
    9D Engine Fuel Rate 256*A+B/50 0 1310 0.02 g/s 07DF019D 0441859D0000 2810 000100050000 EFR
    9D Vehicle Fuel Rate 256*C+D/50 0 1310 0.02 g/s 07DF019D 0441859D0000 3810 000100050000 VFR
    9E Engine exhaust flow rate
    9F Fuel system percentage use
    A0 Supported PIDS (A1-C0) Hex -Bit encoded n/a n/a n/a 07DF01A0 044115A00000 2810 / 3810 000100010000 Output is in Hex - From web resource decode meaning of each RXD set - 2810 is for AB bits 7-0 / 3810 is for CD bits 7-0
    A1 NOx sensor corrected data
    A2 Cylinder fuel rate 256*A+B/32 0 2048 0.03 mg/stroke 07DF01A2 044105A20000 2810
    A3 Evap system vapour pressure
    A4 Transmission actual gear 256*A+B/1000 0 66 0.001 ratio 07DF01A4 044185A40000 2810 000100640000
    A5 Command diesel exhaust fluid dosing A/2 0 128 0.5 % 07DF01A5 044105A50000 2808 000100020000
    A6 Odometer (A*4194304+B*32768+C*256+D)/10 0 429496730 0.1 km
    A7 NOx concentration 3, 4
    A8 NOx corrected concentration 3, 4
    See these links for addition info and assistance with individual PID decodes:
    OBD-II J1979 PID Listing (dashlogic.com)
    OBD2 PID Overview [Lookup/Converter Tool, Table, CSV, DBC] – CSS Electronics
