What have you used your winch for?
  • What have you used your winch for?
    Hi everyone,
    As far as I can see this topic has not been mentioned. But I am wondering what strange, unusual, or perhaps clever applications have you used your winch for?
    I have a Terrain Tamer hand winch which proved invaluable today. My father asked me to bring my chainsaw and help him fell a tree in his backyard. This tree was terribly rotten inside and presented a significant danger to ourselves and dad's house if we simply tried to fell it with a chainsaw.
    I used my nogin and rigged up my Terrain Tamer winch and we pulled this thing down beautifully from a nice safe distance...
    Needless to say, my dad who only drives a Ford, was suitably impressed and "wants one of those winches!"
    Anyway, just wondering if anyone else has used their winch for anything other than vehicle recoveries?
    Greg Simpson "Simmo"
    Simmo's Offroad Tours
    Winery Tours - Scenic 4WD Tours - Camping Adventures
    Orange NSW
    [url="http://www.simmosoffroadtours.com"]www.simmosoffroadtours.com[/url]
    2006 Toyota Prado TD GXL, Dune in colour.
    Sovereign Bullbar, Hella lights, cargo barrier, Opposite Lock Rackmaster racks, Waeco 60L Fridge, Cooper STT's, Sandrabba Matts, GME TX3400,
    Moving trees is a common use for the winch
    ...If its not on all 4's it's not on.....
    2008 GXL D4D, OME lift, arb bar, IPF 55W HIDs, HID headlights, duel Batteries, Winch, UHF, Safari Snorkel, bfg km2's, arb side awning, rola cage, engel fridge, kaymar rear bar(to fit)
      Re: What have you used your winch for?
      Sligtly off topic but I once used a (strong) rope tied to the front of a Hilux I had to remove a 4 cylinder engine from a Corolla. Looped the rope above the engine and through a steal patio beam then inched the luxy bacwards gently (low range) and lifted the engine out.
      Technically not a whinch I know but would certainly do the same job.
      Things you do when you are alone.....
      Chriso
      [COLOR=blue]Current rig - 150 GXL D4D Auto TJM bullbar. Airtec Snorkel. ARB Underbonnet Comp.
      Previous rig - 02 TD GXL.[/COLOR]
        The wife wanted a half wine barrel full of dirt and a tree moved. There was no way you could budge it with human power. So I threw the tree trunk protector around it and winched it into its new position in the garden 8)
          :arrow: Pooling a stuck Pootrol out of the bog :twisted:
          and
          :arrow: Making a flying fox for kids to have some fun while camping
            I installed a new concrete septic pit a couple of years ago. Took a bit of thinking and a couple of snatch blocks to manouver it into position.
            I have also positioned 2 big water tanks into the exact location, pulling and twisting them. They were not overly heavy (about 600kg) they are just arkward to man handle.
            Adrian
            2004 GXL TD 3.0 ARB deluxe bar, Warn winch, IPF Driving lights, Pirhana Dual Battery, Pirhana Dual Battery Monitor, GME UHF, ARB air compressor, Custom storage/ fridge slide, ARB roof rack, Safari snorkel, 2" OME suspension lift, Mickey Thompson MTZ
              I had to remove a security fence which was a cyclone fence with barbed wire top. The posts were concreted under ashphalt! I hooked up the LR110 winch and gave it all she had ... skull dragged the 110 to the post. Ended up "removing" the posts with an angle grinder, cutting them off at ground level
              [b]2000 Prado RV6[/b] ~ TJM Type 15 Steel Bullbar ~ Uniden 400SX-RM & GME4702 Ant ~ Front Tow/Recovery Hooks ~ ARB Recovery Kit ~ ARB CKMP12 Air Compressor ~ DIY Rear Door Trim & Table ~ Extended Diff Breathers ~ Safari Snorkel ~ Wireless Reverse Camera ~ Iron Ox Full Length Roof Rack ~ Looong Wish List ...
                Adrian
                Ive gotta shift a couple of 5000 gallon tanks a couple of metres soon. Looks like i will HAVE TO get the winch soon. :wink:
                  i too have used my handwinch only for backyard operations. ( never used in recovery ). I quickly found that the winch is only as good as the anchor point. ops: Used for straghtening the back fence, pulling out stumps. I hear that can also be effective as a tensioner for fencing.
                  I went past a travelling circus, noted about 20 Tirfors being used as tensioners on their guy ropes for the big top !
                  Cheers, Wayne
                    Would love to see a photo of this Stan, that is if you have one. What did you use for the carraige mechanism?
                    [COLOR=#000080]Nick[/COLOR]
                      Many hours spent pulling the lift pump shafts on windmills, using the winch was a lot easier than tying a wire rope around the tojo bullbar and reversing, some shafts had 4 or 5 sections.
                      Bribiejohn
                        Damonat had to recover a bogged honda civic out in barrington tops, after we told them not to go down that track, they proceded with a flat rear tyre (17inch rims) and a space saving spare on the other rear. fkn retards!
                        2000 Toyota Prado GXL- Gone, but not forgotten...
                        '92 Landcruiser HDJ80 4"lift 33's
                        '91 Surf LN130 coil sas, 4.8s, 35s
                        '12 Jayco Eagle Outback
                          I regularly use my winch to get my camper trailer down our drive without mishap. We live on a block with a fairly steep driveway. The gap between the gate is only about 2 inches wider than the CT on each side. Also, the drive way curves around a bit.
                          I got a remote control for the winch, and use it to let the winch out a bit at a time, and guide the CT by hand. Haven't bashed the gate since. Similar for bringing the CT up the drive.
                          Nuge.
                          Nuge.
                          Silver 2006 Petrol - 2" OME lift, Air Lockers, ARB Sahara Bar, Warn 9500 winch, Safari snorkel, HID driving lights, dual batteries, Glind shower, UHF radio, sat phone, Waeco fridge.
                            Pulling 100 year old logs out of abandoned mine shafts to use on the camp fire.
                            They are generally rock hard and termite free and burn for hours. The tricky part is doing it safely without falling down the hole!
                              Came in very handy to be only car with a winch on recent central Oz trip.
                              Had to pull out both of the Patrols (with campers) that were also on the trip...was very wet through the Simpson and around Mt Dare in August.
                              2009 120 Prado D4D TD,Auto. Koni/RidePro coils, polyair rear bags, 2nd set alloys/Cooper STT 265/70/17, safari snorkel, bonnet scoop, kaymar wheel spacer, drawers, scan gauge II, roof console, UHF, Hema gps, Tmax winch/plasma rope, Brown Davis b/plates, LED light bar, Redarc charger, ARB compressor, Tambo Camper, Stainless Exhaust, maxtrax, Stein Chip, ARB 78ltr fridge, ARB Rear locker.
