KZTE problem, motor cuts out
  • KZTE problem, motor cuts out
    I have a 2003 Prado 3L VX with the KZTE diesel motor
    It has a Perfect Power SMT6 chip and an intercooler, besides that it is standard.
    The problem I have been having is that every time I start the vehicle and drive for about 2 kms the engine Management light will come on and sometimes the glow plug light and then the motor cuts/goes to stand by mode. This will happen about 5 to 8 times and then will be OK for 600 kms ( no stopping). Every time I fiddle with the chips wiring it seems to change the fault or fix it. The ECU code is 12 which states that the crank sensor is at fault, I replaced this and still the same.
    I have replaced the SMT6 chip, and still the same, replaced the resistor and sputnick thingy (Little blue thing stating numbers in micro Farads used for the installation of the piggy back chip)) and still the same.
    Any ideas?
    Regards
    Rob
    Re: KZTE problem, motor cuts out
    Can you go back to standard to eliminate the chip & its wiring altogether? Depending on the result of that will show you where the issues lie..
    Richard
    2011 GXL TD Auto Prado Silver
      Hi
      Will try that and let you know
      regards
      Rob
      Regards
      Rob
        Hi
        Took out the chip and it is still the same
        regards
        Rob
        Regards
        Rob
