Stop the Bugs
  • Stop the Bugs
    What's the best way to stop grasshoppers getting in the radiator?
    I'm driving through the Hay Plains next week and I know there will be millions of the things ready to hit every car that comes their way. Is it better for airflow to use flywire or shadecloth on a turbo diesel?
    Re: Stop the Bugs
    Hi Gramps,
    You can buy an actual Toyota mesh screen that goes over the grill and attaches via some long screws and clips, otherwise I reckon shadecloth cable-tied to the grill will do the job without any issues.
    Confidence - The feeling before you fully understand the situation
      Re: Stop the Bugs
      Thanks Dave,
      I have a feeling that the genuine ones cost a bomb that's why I didn't mention them before. My main concern is, will the larger fibers of the shadecloth restrict airflow to the radiator? I don't want to be stuck in the middle of nowhere with a camper and kids because of overheating.
        Re: Stop the Bugs
        One quick way to find out if the airflow is restricted with shadecloth - rough cut piece, a couple of cable ties and a quick drive around for an hour or so wtaching the temp gauge closely..... Better to do it around home than out on the tracks for sure.
        Genuine Toyo part was $120 or so from memory.
          Re: Stop the Bugs
          I have the genuine insect srcreen and it works well. Problem is the slot in the ARB bar lets the bugs in so you need to add something to that too.
            Re: Stop the Bugs
            Shadecloth would be fine, I have never had an issue with temp. Use fibreglass flyscreen otherwise.
            Also WAX the front of the car and roofline, it makes it heaps easier to get the bugs off later.
              Re: Stop the Bugs
              I have used shadecloth for quite a while and the temp gauge hardly moves. Just keep an eye on it for the first few kms and you will see what temp it will run at. With mine you could hardly see the difference.
              Also with the shadecloth, make sure it covers the intakes for the intercooler if you have the diesel which are on the top left and right corners of the grill from the front. Lift the bonnet and have a look for them. The air runs up through the bonnet lid through two channels and down into the top of the intercooler and I didn't have those covered by the shadecloth the first time and the intercooler got full of hundreds of grasshoppers. They got sucked in. I attach my shadecloth to the clear plastic bonnet protector with 4 bulldog clips at the top and at the bottom with 4 more bulldog clips at the back edge of the front plastic bumper. It then covers all of the front grill area but not the lights.
              [color=#fa0c23][b]
              Brian
              [/b][/color]
              [color=#004080][b]2011 Silver GXL Diesel Auto with dual batteries & pirellis etc often pulling a Jayco Discovery Outback
              [/b][/color]
                Re: Stop the Bugs
                Here is a picture I've found. Shadecloth only costs a couple of dollars from a hardware shop and you only need a couple of metres and it is softer than mesh and doesn't rub against or ruin your paint.
                [/url]
                image uploading[/img]
                As you can see we pull the Jayco with it too and the temp gauge doesn't move.
                [color=#fa0c23][b]
                Brian
                [/b][/color]
                [/b][/color]
                  Re: Stop the Bugs
                  Also wise to carry a few pre-cut pieces with you just in case it breaks or goes missing.
                  I wonder if glad wrapping the panels, lights, spotties will assist in bug removal (assuming that you aren't using the spotties as I'd imagine that it would melt the glad wrap). Maybe on the windscreen as well assuming that there was no rain...??? Then when it's done it's job, peel off and apply another layer.
                    Re: Stop the Bugs
                    Sure fire way of stopping grass hoppers getting into the radiator of the prado is to leave it in the shed and take a different car!
                    If this is not an option - then anyone of the afore mentioned methods will work...
                    Matt
                      Re: Stop the Bugs
                      Wrap will tear in the wind. Waxing is the easiest way i find.
                        Re: Stop the Bugs
                        Yeah, a rental will do.
                          Re: Stop the Bugs
                          Open weave shadecloth, cable ties and a couple of bulldog clips it is.
                          Much appreciated guys.
                          Gramps
                            Re: Stop the Bugs
                            most auto upholsterers have stuff they use to add into car bra,s it allows more air flow than shadecloth,it comes in a 3 mtr roll,so they sell as much as you want,good luck
                              Re: Stop the Bugs
                              Shade cloth works just fine.
                              Cut the cloth about 10-15cm wider that uprights or width of the radiator intake and make it about 1 m long.
                              Attach it only at the top. I.e. cable tie it to the top bar on your bull bar and leave the longer end flap free under the car. The longer end needs to be long enough so that the wind force keeps the top stretched in position.
                              With this setup, it is a quiick clean up, when you get heaps of bugs they can be flicked off easily when you stop. You don't need water or a brush to get them off.
                              Putting about 50mls of metho in your washer reservoir will help clean off all the guts from the windscreen.
                              If you are going to live out here get a wind/bug deflector on the front bonnet.
                              I came across the Hay plains about a week ago, it seems most of the swarm has moved further south.
                              Don't drive through swarms with the driver's window and driver's mouth open !! they deflect off the mirror into your mouth !!!! :lol:
                              "Ooops I just deleted the internet, lucky I was able to recover 99.7% of it out of the bin" :lol:
