I have purchased a sat nav unit from easy park in Sydney and can not get the reverse camera to work on my 150 series vx have checked the wiring from the Toyota wiring diagram can any one help
Reverse camera
Does the reverse camera have a standard composite video connector on it? You could test the camera by plugging it into a TV or portable dvd player.
What do you mean by 'does not work'? Does the screen on the gps change when you select reverse?2008 D4D M6 GXL [MT ATZ-P3][Whitey's Ironman 45710FE/45682FE+KTFR101H/Dob487][extended Roadsafe links][Polyairs][DBA T3/T2][amts diffdrop & recovery points][Tin175's stone guards][Bushskins BashPlate][ARB Sahara][IPF 900s][Snorkel][WindCheetah][MaxTrax][IC-440][Parrot Asteroid][ARB Fridge][Lifestyle 2nd Row Fridge Mount][ARB Compressor][Thumper][SandGrabbers][Cargo Barrier][Tigerz Awning][MCC Rear Bar]
So the display doesn't change at all when you select reverse?
In that case there is something wrong with the sense wiring. If you read up on the wiring diagram for your kit, there should be a wire that hooks into the reverse lights circuit. When you select reverse, the unit senses the voltage and switches to the camera display.
Other than that, I guess it might be a setting on the unit itself. Have you asked easy park about it?2008 D4D M6 GXL [MT ATZ-P3][Whitey's Ironman 45710FE/45682FE+KTFR101H/Dob487][extended Roadsafe links][Polyairs][DBA T3/T2][amts diffdrop & recovery points][Tin175's stone guards][Bushskins BashPlate][ARB Sahara][IPF 900s][Snorkel][WindCheetah][MaxTrax][IC-440][Parrot Asteroid][ARB Fridge][Lifestyle 2nd Row Fridge Mount][ARB Compressor][Thumper][SandGrabbers][Cargo Barrier][Tigerz Awning][MCC Rear Bar]
Some guys have installed aftermarket head units, and the camera hasn't worked, they figured out that the Toyota camera runs a different voltage to the head unit. Something to check outGeoff
Peter there is a thread in the 150 section on aftermarket stereo installations, I have done up some pictures and instructions on what I did. I know some other members with GXL and VX's that have followed them with successful results. I'll post up a link in the next couple of days.[SIZE=2]Black 2009 150 Series D4D GXL Prado, [B]TG150[/B] Transfer Case & Actuator Guard, TJM T13 bar, TJM 9.5lb Winch, Airtec Snorkel, TJM steel sidesteps and sidebars, TJM Underbody Protection, TJM XGS Gold Suspension, Tinted, ARB Fridge Freezer, Couplertec System, Foxwing Awning, 80AH Dual battery, 8" indash GPS, Wet Seat seatcovers, GME TX3540, TX3110 & TX680, [B][COLOR=#ff6633]Maxtrax[/COLOR][/B], Kaymar Dual Wheel Carrier, Breathers, Federal MT's.[/SIZE]
photoprado
