Legalities of using/touching a mounted tablet as a GPS ?
  • Legalities of using/touching a mounted tablet as a GPS ?
    Hi everyone,
    Firstly, apologies if this has been discussed somewhere, I couldn't find it.
    With all the fuss lately about using mobile phones while driving (which I agree with), does anyone have any links to solid information about whether or not one can use a tablet as a GPS and if so, what type of mount is acceptable ?
    I'm in WA so WA law would be ideal but any Australian stuff would be interesting.
    Thanks !
    I don't think you are technically allowed to use any GPS whilst driving be it tablet based or otherwise although the link is sketchy on GPS.
    http://www.keepyoureyesontheroad.org.au/pages/WA-laws
      thanks for the link kenny5000, from that:
      Visual Display Units (e.g. a GPS unit or other navigational device) must either be:
      - An integrated part of the vehicle design; or
      - Secured in a commercially designed mounting, affixed to the vehicle while it is being used.
      so I guess a ram mount or similar should be OK.
        And a WA gov link
        http://www.ors.wa.gov.au/Documents/L...ile-phones-faq
          As long as the tablet is mounted, and affixed to that mount whilist using it, you can use a GPS or even a phone 'navigational system'. Examples are in the legislation below.
          http://www.austlii.edu.au/au/legis/w...0113/s264.html
          However, if something occurred whilst using it i'm sure there would be numerous other legislation for failing to maintain proper control of a motor vehicle, like there is here in SA.
            hmmm from the 2nd link kenny5000 posted:
            Using the GPS function of a mobile phone
            The GPS function of a mobile phone may be used by a driver while driving as long as:
            • the phone is secured in a mounting affixed to the vehicle; and
            • the driver does not touch the phone (including the keypad or screen) at any time while driving.
            Unless the GPS function can be activated and programmed without touching the phone using the GPS
            function on a mobile phone will require the vehicle to be legally parked at the time the driver turns the
            GPS function on, programs or resets the GPS, and turns the GPS function off.
            so you can look at and listen to the GPS function of a mobile (and I assume tablet) but not touch it. so no reprogramming routes etc.
