Ozi Explorer update
    Re: Ozi Explorer update
    Originally posted by HGMonaro
    I find the 'Auto Set Time' option on the 3rd Tab in General Settings but can't see anything that lets me set the time zone. Mines a Win5.0 device, wonder if that matters?
    I'm not currentlty running 2.32 but I'm sure it was the third tabv (don't recall the name) and the default setting for the field was "Windows Time".
    I can't really give your more info than that because my PC stuffed up and can't get onto it so I'm currenlty using my kids one. The other one had all my GPS gear on it.
    [COLOR=#000080]Nick[/COLOR]
      no probs.. I'll research (read the Ozi page) a bit more!
        The timezone setting is in the last tab past the Auto Time check box.
        Mines set at GMT +10 for East Coast Australia, timezone Kilo.
        Also I think it's getting it's time from the GPS Signals.
        And I have not yet had to enter my registration code yet, i'll have to try it on my 4.3" too.
        Snowy
          been a bit slack, here's the last few updates for the pc version
          Release Version 3.95.5g (December 2009)
          Fixes
          Fixed issue with 24bit color tif image support.
          Fixed issue where internet maps would stall (stop loading tiles).
          Fixed an issue with routes in gpx files.
          Fixed an issue with AIS configuration where the "Ship Label" settings were not being saved.
          Changes
          Added latest Garmin GPS models to the selection in configuration.
          Added support for lower case and extended characters for Garmin GPS.
          Added moving map support for the Garmin Nuvi, Zumo and Streetpilot models when connected to the PC by the special Garmin serial cable. These use the PVT protocol. Only tested with the Nuvi 760 but it is assumed other models mentioned will work.
          Release Version 3.95.5f (October 2009)
          Fixes
          moving map compass display fixed for non 100% zooms.
          some fixes and improved support for XP and vista themes.
          Changes
          Google maps changed their map url, this has been fixed.
          New Zealand have released their new NZTM topo maps so have added support for New Zealand NZTM grid and datum.
          Added support for the new topo maps for New Zealand. The topo50 maps are 24bit color geotiffs, the topo 250 are 24bit color geotiffs but stored within the tif as color planes (an unusual tif format for PC use).
          24 bit color tif files can now be paged instead of having to be fully loaded into memory.
          Added support for loading planar configuration tif files (but not paged - must be fully loaded).
          Automatic Ship Identification (AIS) help is now listed in the Help contents.
          Added the ability to store altitude in kml files.
          Release Version 3.95.5e (September 2009)
          Fixes
          Exporting waypoints to text file fixed.
          Some minor cosmetic issues fixed.
          Changes
          Added the new Garmin Dakota to the GPS list.
          Project Manager
          When a project is loaded the tracks are now loaded in the same order that they appeared in the Track Control when the project was created.
          You can now specify a map position where the loaded project starts.
          OziExplorerCE .rt2 route files can now be loaded, rt2 files cannot be saved but OziExplorerCE can read OziExplorers .rte files.
          Added a Zoom Number display to the Internet maps control toolbar.
          Release Version 3.95.5d (August-2009)
          Fixes
          Fixed issues with Update options on Help menu not being remembered.
          The change of compiler caused some unusual issues on some systems.
          Changes
          Added support for Open Street Maps and Virtual Earth Internet maps.
          Google Maps support now works differently, it is part of the "internet maps" control, script errors should no longer happen. The Google Maps.map file will still work but is no longer provided - use the Internet Maps.map file instead.
          Changed Google Earth support so the Google Earth software is no longer closed until OziExplorer is closed.
          Release Version 3.95.5c (August-2009)
          Fixes
          Fixed issues with shape file import and export.
          Changes
          Added support for USA Terraserver maps.
          Added zoom level menu to Google maps.
          Added ability to sort on CPA for the AIS (ship indentification system).
          Release Version 3.95.5b (August-2009)
          Fixes
          some more minor fixes.
          Changes
          Now includes support for Google Maps within OziExplorer. There is a link to the OziExplorer Google Maps page (on the OziExplorer page) where the .map file can be downloaded.
          Some fixes done for the Google Earth support.
          Added the ability to check if there is an update available. The default is a daily check but can be changed using the option on the Help menu. The update is not automatically downloaded but you are advised if there is one available and the changes that have been made.
          Release Version 3.95.5a (July-2009)
          Fixes
          some minor fixes.
          Changes
          Now includes support for Google Earth within OziExplorer. There is a link to the OziExplorer Google Earth page (on the OziExplorer page) where the .map file can be downloaded.
          Fixed some unusual Vista issues.
          Added support for AIS (Automatic Ship Identification) system. The option is on the Moving Map menu. This is the same as included in the development version of OziExplorer.
          Changed to a new version of the compiler used to develop OziExplorer.
          Black 2008 D4D GX, Bolle tint, Airtec snorkel, Hayman Reese tow bar, Staun deflators, ARB Air, front & rear extended diff breathers, Milford cargo barrier, Poly Air, 2" lift, XGS suspension, road tyres - 265/65x17 Grandtreks, play tyres - 265/70x17 Wrangler MTR's, ARB Sahara Bar, TMax 9000 winch, custom winch panel, Uniden UHF, Garmin 76csx with RAM mount, Eee PC with OZI, triple IPF 900XS spotties, rear ARB diff locker, Brown Davis underbody protection, Darren McRAE Auto Craft Rock Sliders
            And for the CE version....................
            Release Version 2.32 (December 2009)
            Changes
            Added support for New Zealand NZTM 2000 grid and datum.
            Added time zone support within OziExplorerCE (on the "General Settings" configuration dialog) .
            Fixed some compatibility issues with Windows CE 6 (saving of the "General Settings" dialog is fixed).
            Fixed issue with missing the last character in the attachment name when reading in waypoints from the waypoint file.
            Fixed magnetic variation calculations.
            Alerts (which cause an alarm to sound when approaching a waypoint) were a special form of a waypoint proximity. Alerts are now totally separate from waypoint proximities and therefore the proximity distance is no longer set to a negative number.
              I've been a little bit quiet of late....here's some more ozi updates for your info
              CE version -
              Release Version 2.33/2.33a (June 2010)
              Changes
              * 2.33a - Fixed freezing issue when language other than English is used with a larger menu size.
              * 2.33a - Fixed speed display being incorrect when using managed GPS.
              * 2.33a - Fine tuning of parameters and buttons displayed on the map when the map is expanded.
              * Fixed issue where the track point time in the track log file was not being stored in UTC time.
              * The time zone is now stored in the track log file, the next version of PC OziExplorer will use this entry to display the track points with the time they were collected.
              * Added support for the Microsoft "managed" GPS interface for Pocket PC's / Smartphones. If your PDA has a "Managed" GPS then it will always be found first and used when the "Auto" GPS configuration option is specified. If you do not want to use the "Managed" GPS then the GPS port must be selected manually.
              * New configuration options have been added in "General Settings" to allow sizes to be specified for the following items (useful for the devices with high pixel density screens).
              o Size of the font used for the "Standard menus"
              o Size of the Dialogs
              o Size of the Toolbars
              o Size of the Menubar
              o Size of the Keyboard (wince core devices only)
              * The screen pages are now resized by scaling to fit the screen rather than by moving the parameters - this givers a better look.
              * New API functions have been added for "Start / Stop Navigation" and "Load Route File"
              PC VERSION
              Fixes
              * AIS - Class B vessels now display the name and other parameters.
              * There have been a few other minor fixes.
              Changes
              * Added / fixed support for the Garmin Dakota and Oregon x50 GPS models.
              * Added support for the Garmin GPSMAP 78 and 62 models.
              * The Garmin Oregon and Colarado can now be used for Moving Map - Set the GPS Interface to "Garmin Spanner" (do not install or start the Garmin Spanner software, it is not needed) - connect to the PC using normal USB cable - on the GPS screen set mass Storage Mode OFF - in OziExplorer configuration make sure "Garmin USB" and "Use PVT for Garmin instead of NMEA" are both checked - start moving map in OziExplorer.
              * Added time zone offset into the track files and the offset can be edited in track properties. Any display of a track point time will use the time zone offset if it is available.
              * The User Toolbar can now have different sizes. The setting is on the User Toolbar configuration dialog.
              * A Find GPS Port button has been added to the GPS tab in OziExplorer configuration. The ports on the PC will be scanned and the information about the GPS found will be displayed so the information can be manually entered into OziExplorer configuration.
              * Options for More and Less Detailed Map have been added - the options can be added to the User toolbar or Function keys, they are not available on the standard menus.
              * More Internet maps have been added - by opening the Internet map the new maps can be seen on the drop down menu.
              * Added option to Internet maps to ignore the cache so new tiles will be downloaded from the internet.
              * The help for OziExplorerCE has been removed from the OziExplorer help to reduce confusion between the two programs.
              * For Windows Vista and 7 the default folder where OziExplorer stores its system files has been changed to "c:\{user}\.OziExplorer" , this has been done to make it easier for users to find these files (the AppData folder which was used by previous versions is hidden by default in Vista and 7). Please Note - existing installations will still use the same folder they are currently using, this ensures your configuration files will still be found
                And an upgrade on the PC version out also
                Dune colour GLX with Option pack, Bull bar, Tow bar, Cargo barrier.
                  Version "K"for the PC has been released...
                  Direct cut and paste from ozi as below
                  Changes
                  * 3.95.5k - Added support for the new Garmin Zumo 220 and Nuvi 1490 models.
                  * 3.95.5k - Updated map version number in the url for for Google Satellite maps (part of Internet Maps).
                  * 3.95.5k - Fine tuning done for more and less detailed map option.
                  * 3.95.5k - The printing of the route list has been improved.
                  * 3.95.5k - Changed how the first waypoint in a route is handled when navigation is started - the proximity zone no longer defaults to 100 meters but is now the same as the "Route Waypoint proximity" setting.
                    A update of OziCE (2.34a) was issued on 7 Oct.
                    Updates include
                    2.34a - The cross at the center of the screen was not being drawn when dragging the map making it difficult to position the map at a specific location - now fixed.
                    2.34a - The map cursor position lat/lon (center of screen) was not being updated after kinetic scrolling - now fixed.
