Re: Dig_Options TP09X1 GPS, Reviews & Information
  • x2..........
    • Bought my Digoptions a few weeks ago. Unfortunately it was faulty (Radio U/S) and I had to return it. After a couple of emails to & fro Matt sent a replacement which worked perfectly.
      The service I received was excellent and proves that some companies can provide good after-sales support.
      I am not too sure I would have received the same level of satisfaction had I bought direct from China. To me the extra few dollars dealing direct with Digoptions was good insurance.
      Thanks again Matt
      2008 White Petrol GXL Auto with lot's of fruit and more to come.
      • Originally posted by Ozpat View Post
        Got my update from Matt. Will take a a while to download (900mb) Can't wait to install.
        Better off to install onto a blank sd card and keep the old one as a backup.
        Cheers, Jim..
        Hey Jim, I have it all installed. Its not as different as I thought it would be. Just has a new menu. I need some time to work out all of the new menus and all the addons.
        90 series prado with lots of stuff.
        • Guys, is there any trick to adding the gps coordinates into the dig options unit as when I try to enter I can only enter the first two like 25 etc.
          Your help would be appreciated
          • Quick quesiton on the digioptions software upgrade.
            Are the GPS maps upgraded or is it just a menu change?
            [B]Robert
            • I can't believe this post has 77 pages, also looking forwarded to the feedback on the update
              ...If its not on all 4's it's not on.....
              2008 GXL D4D, OME lift, arb bar, IPF 55W HIDs, HID headlights, duel Batteries, Winch, UHF, Safari Snorkel, bfg km2's, arb side awning, rola cage, engel fridge, kaymar rear bar(to fit)
              • Originally posted by gumboot View Post
                Upgraded mine last night. Street maps are upgraded (Nav n Go iGO 8 May2010 release maps...)I thought iGO 9 would have been included? The NAVI button takes you first to a sub-menu which is the new DigOptions console. I dont think I would ever really use this as the graphics are pretty clunky. Especially the games.... Early days I guess so the jury is still out on this one.
                  Hi Craig,
                  These imlpys the maps are 2 years old then? I dotn understand why it is not iGO 9
                  I see when you go here http://www.igonavigation.com/map-updates-and-extras and then this link
                  https://www.naviextras.com/shop/portal/deviceSelect
                  You can browse the maps but I am not sure what device this actualy is. Does anyone have the right link ?
                  [B]Robert
                    Hi Craig, can I ask if you had any problems with the update, I have the premium unit and can't get the update to work. I have left an e-mail with Matt and hopefully I will get a reply, if you have any suggestions I am all ears.'
                    Thanks Walter MEL
                    • Originally posted by Apriti00 View Post
                      Thanks Walter MEL
                      Did you follow the instructions from Matt and are you updating over the old one? You're much better putting it onto a new micro sd as they're cheap as.
                      Cheers, Jim.
                      [SIZE=1]Cheers Jim.
                      [/SIZE][COLOR=#0000cd]
                      • Exactly the same questions I was about to ask.... I pretty much followed the steps in the instructions and had no issues. perhaps a silly question, but you are unzipping the downloaded file before copying onto the micro sd card aren't you?
                        If you don't want to buy a new card, then copy the entire original contents of the card onto a folder on your computer (backup). Once you've done this, delete everything on the card and to be sure the card is clear, go to My Computer or Windows Explorer, find the SD Card and right click the object and select "Format". This will ensure the card is clean. Then copy all the unzipped files from the AVN Setup Update folder onto the micro SD card (not the actual folder that they reside in). Any further issues, See Matt....
                          Cheers, Jim.
                          Hi Jim,
                          Just about to give up for tonight, Yes I think I have followed the instructions however when I change the path to the WOLFNCU.exe and I try to access the main menu I get an error window that wants me to choose the skin file but no options show up in the window, starting to think that its not compatible with the "premium unit" without some alterations.
                          Also I am using a new card to avoid any possible conflicts with leftover data.
                          Cheers Walter
                          • Walter. When you say you have the "premium unit", are you referring to the AV11TP?
                            • Hi all, just got myself a DIG Options unit and installed last night. Havnt done the reversing camera yet and everything I have tested is working except the navigation (ie CD, DVD, IPod, Radio). When I hit the navigation button the screen flickers for a millisecond then goes blank...Yes I have conected the GPS Antenna I have emailed Matt and he has asked for a video of the issue. Anyone have a similar experiance.
                              • is the SD card inserted in the stereo?
                                More to come!
