Double post. Oops.
Rig Build 120 D4D Grande - 'MLC'
Official response is labour time. I paid the $122, but all hell will break loose when the code comes again and I don't clear it and they cant fix it. accept that I cleared the code but when I dont it will be their (or Toyotas problem).[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Decided to clean the rig and take some photos with both rear tyres on:
Last edited by MidLifeCrisis; 09-03-2015, 09:02 PM.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Better pictures of the Hayman Reece. Note, these are official photos unlike the illegal ones taken by AJ yesterday. I am still deciding whether to press charges after the neighbour called the cops
Also fitted up the GoPro mounts ready for the GTG 2012 trip:
Odd that you got the error code without the chip fitted though the turbo stepper motor on the D4D is known to be problematic.
I've seen the P1251 error code before when playing around with chips that change boost. The turbo stepper motor has a feedback loop that looks for it to be in the correct position within a certain time. When a chip artificially changes the signals to the ECU to gain greater boost the stepper motor has to make great changes from off-boost to on-boost and if it doesn't get to the position in time the ECU throws the P1251 fault. The fault may only become apparent on some vehicles or after a period of time as the stepper motor response varies between vehicles and can change over time.
LeachyLast edited by leachy_9; 23-07-2012, 01:51 PM.EX-Prado Owner
Leachy, so far it hasn't shown the code sionce I had CMI "check it out" I expect it really is a matter of when though.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Originally posted by MidLifeCrisis View PostBetter pictures of the Hayman Reece.
I removed my OEM towbar when I fitted the rear bar on mine and have used the centre, bottom point as one of the points for attaching my bar. I'm guessing that I should be able to fit an HR towbar if I decide I need a towbar?
Trekky
Yes, it attaches in the centre and on each side. After seeing your handy work I am sure you could make minor adjustments if needed, but expect you don't need to.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
While under the car on the weekend I noticed again some damage to the still relatively new Mantra exhaust. That'll learned me for playing with those WA boys at Christmas time!
Originally posted by photoprado View PostRob, have you got a reversing camera?
I'm going to have to re-locate mine from the numberplate light area, (get it working again, too!) and wondering where to put it...[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Originally posted by Matty & Loz View PostThats a nice tree in the background mate, do you alway park under that? Rig looks pretty shmick with both tyres on...[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Originally posted by MidLifeCrisis View PostAlso fitted up the GoPro mounts ready for the GTG 2012 trip:
