90 series Turbo Diesel Family Bus!
  • 90 series Turbo Diesel Family Bus!
    Well ive owned it for two weeks now so time to start the modifying!
    Here are the details:
    2000 TX Turbo Diesel Manual
    5 x New All terrains
    Bilstein shocks and Lovells springs
    Arb compressor
    Arb front and rear diff locks
    Duel batteries
    Ironman winch bar
    Safari snorkel
    Turbo timer
    Boost guage
    3 inch mandrel bent exhaust
    DP chip
    diff breathers
    towbar
    New heavy duty clutch
    I just picked up a winch, spotties, rear drawers, ARB compressor which will all be fitted over the next few weeks...
    lockedup
    Front and Rear ARB Air Lockers - Maxxis Bighorn 32inch M/Ts - Black 16x8 Sunrasias - Bilstein shocks - Lovells springs - Duel batteries - Ironman winch bar - Safari snorkel - Turbo timer - Boost guage - 3 inch mandrel bent exhaust - DP chip - Diff breathers - Custom Drawers - Towbar - Cargo barrier - HID spotties - Roof cage - Rear floodlight - Arb compressor - Garmin 1490T with Topos - 12000 Winch - Ozito chainsaw blah blah blah
    Pick up roof racks and roof basket and waterproof bag on sunday - would rather a full rack but this was a cheap alternative til i can afford different...
    I am also making a rear light for camping...
    lockedup
      After the primer i added two coats of black then a coat of clear!
      After bolting up the light i am not totally happy with the weight it will be putting on one bolt. I will bolt it up then decide if it will be coming off for a second arm welded on...
      Next will be a three way switch in dash with the options: ON/OFF/REVERSE...
        Looking good mate.
        Gee, with lockers, lift, snorkel and bar etc your rig would be unstoppable!
        There can't be much left to do now.
          Originally posted by williade View Post
          Looking good mate.
          Thanks mate, it does go alright but always something on the wishlist!
            my drawers require a custom cargo barrier and i got quoted $500 delivered... this one cost me $40 in paint and a few bolts...
            trial fit!
            coat of primer
            1st coat of black!
            lockedup
              Winch nearly finished and spotties on... Damn HID's light up the road... Awesome... Tomorrow the cargo barrier will go in. Finishing winch, put on roof racks, basket and rear flood light will be next weeks job as busy all weekend.
                Looking the goods lockedup, who's handy with a welder then? Not much going to stop you progress, well done so far,
                cheers,
                Dennis
                Ag Nomad
                  Thanks Dennis, welding is always a learning process! Saving $$$ is the main motivation... Scrapped rear floodlight mount and it's going on rear of roof cage...
                    Winch on!
                    Spotties on!
                    Cargo Barrier in!
                      And burning the midnight oil I see?!
                      cheers
                      Dennis
                      Ag Nomad
                        Bought an awesome recovery kit today... Hopefully the brand holds up ok, Black rat...
                        Contents:
                        3m Tree Trunk Protector
                        Black Rat Snatch Block
                        2x 4.7 Tonne Bow Black Rat Bow Shackles
                        1x Leather Gloves
                        1x Tyre Deflators
                        1x Recovery Hitch with pin and Shackle
                        $213 express posted... All i need now is a winch extension ($65) and should be a bit better equipped then!
                        Still waiting for time to put roof cage on and wire up flood light and winch...
                        Winch control box is going to be put up near the firewall so a bit of a delay while i chase up extended wire.
                        I replaced the blown rear light with a ebay special LED light and DAMN! it is so much brighter. I was going to LED the back area but i think this will be enough for now...
                          roof basket on and rear flood light connected...
                            All wired up via relay and a neat blue switch which lights up when floodlight turned on... Not a bad light considering it was only a $40 supercrap jobby... A duel LED upgrade might happen one day... I like how i can angle it down to face into my cargo area which gives fantastic light for cooking, repairs etc
                              Also am tinkering with the solar panel... it is flexible so it can be tied onto roof or layed over bonnet while stopped... Hopefully should give a good trickle charge to the second battery which will give me a bit more confidence in running the floodlight for a bit longer than normal...
