MUMSRIG..... need I say more
  • Originally posted by 8608 View Post
    Nice work there.
    what did you use to clean the underside up with.
    keen to see how they work and perform.
    Originally posted by Matt - mr4x4 View Post
    Mitch, what did ya use to clean up the underside ?
    Just degreased and high pressure cleaned it all down and then gave it a coat of satin black. Nothing special, just a light dusting to make it look newish again...
    Just the short drive I took felt soo much better then before. Heading to Newcastle in the morn, so it will cop a few bumps on the black top on our wonderfull NSW roads aye Matt
    • Yeah, ya gotta love these wonderful NSW shitbox roads..
      [CENTER][B][U]Matt
      [/CENTER]
      [SIZE=2]
      [/SIZE][CENTER][SIZE=2]
      [/SIZE][/CENTER]
      • Great write up Mitch! Thanks for sharing.
        I thought you put your sliders on the market?
          I did a long time ago. But they eventually ended up back on MUMSRIG and have stayed there ever since
          • Originally posted by MUMSRIG View Post
            Shhh... you are starting to show my age! In fact, you are showing both of our ages!
            I suppose our respective 'Join Date' kinda give it away.
            • Looks awesome mate ..
              great to see there are still on going mods being done !!!
              As Madkore has said we are showing our age!!! ha ha
              cheers Joey.
              -issue 52 Modified 4wds .
                cheers Joey.
                Gosh... I hadn't even looked at the join dates.. WOW 2007.. Seems SOO long ago!!
                • Spent yesterday afternoon at Singleton Exhausts reconfiguring the remote resevior mounts as there was a pretty good chance that they would be hit by the tyre under full travel and lock with the brackets that came with the kit, plus the drivers side could not be used as the washer bottle is in the way. We simply made up a bit of plate and angled it to come of the chassis, inserted a net set to have something to bolt it to in an existing chassis hole and expanded and cut a bit of exhaust tube to use as a saddle, welded, trimmed and fitted.. The reseviors are well out of the way now and i've just got to pull it all apart again to give them a splash of paint... Jobs done!
                  Will post some pics later
                    good stuff mate. Called in yesterday and forgot you had this job on the go ! Lookin forward to seeing the set up in the flesh..
                    [CENTER][B][U]Matt
                    [/CENTER]
                    [SIZE=2]
                    [/SIZE][/CENTER]
                    • I just realised that I haven't posted the picture up of MUMSRIG that Brett from 4WD Action posted on Facebook...
                      • How did you remove the front struts? I tried a coil spring compression tool etc to no avail.
                        Winston.
                        Winston.
                        • Originally posted by winniliss View Post
                          Winston.
                          the front strut assembly comes out as one, and then you can dis assemble it.
                          do not undo the top nut in the car.
                          you need to seperate the upper arm from the knuckle and dis connect the sway bar links.
                          SIK-120
                          2008 Toyota Prado 120
                          • Mumsrig in 4WD Action?
                            When did that happen Mitch?
                            • look familiar... who needs 4wd ACTION mags , when you can be famous on EBAY
                              http://www.ebay.com.au/itm/TOYOTA-PR...ht_1565wt_1024
                              cheers butane
                              • Funny though that the photo used is a faint resemblence of what Mumsrig looks like now!
