Shamozzles silver 150
  • Shamozzles silver 150
    G'day all,
    Now that I've had my manual Silver GXL 150 for a few months I thought I'd start a build thread. I've had more than a few months to formulate some ideas within my head and slowly but surely those visions are beginning to take shape.
    I had the vehicle delivered with an ARB winch bar fitted, a Manta Pro 3" exhaust and factory cargo barrier and tow bar fitted. Since then I've fitted the Lightforce XGT's that were carried over from my old Surf. An ARB battery tray was fitted next with an Optima 50A/h battery to handle the secondary duties of running the fridge, compressor, power outlets, rear reverse light and overhead led light that'll provide light once the Trek Tech rear drawers and table are fitted, hopefully sometime this following week.
    The Optima Battery will eventually be topped up via an 80w solar panel and regulator to extend discharge life, although that will have to wait until the Tracklander roof rack is fitted sometime in the near future. The rear fuse box is supplied via a 16mm2 feed from the Optima battery controlled via a 50A waterproof circuit breaker mounted under the bonnet.
    This runs down the right hand side of the vehicle and terminates into the fuse box wich is located in the compartment above the jack compartment. There are two cigar outlets and one hella type outlets located in the LHS guard trim and a battery charge indicator courtesy of ABR Sidewinder. Each of these rated for 120w/10A. the Led light located on the swing out door is supplied from the same fusebox with cables fed through the standard rubber connection between the body and the vehicle. There is also a spare feed pre ran into the rear door for the future reverse light. All that is left to do now is work out where the anderson plug fitting for the fridge will reside, I'll work this out once the drawers arrive and also the wiring and relays for the compressor, also to be completed when the drawers arrive and I work out where the compressor will be mounted. I'm pretty stoked with the install. It's neat, tidy and does more than the job it will be required for.
    I installed the Warn 9.5xp in the winch bar after reconditioning it, this was also carry over from the previous vehicle. Wiring is 35mm2 and the winch solenoid box will mount up neatly on its side in front of the RHS firewall once I get the bracket made up at work. The winch will be controlled via a dash mounted rocker switch as it was in the previous vehicle.
    UHF is an older type GME remote face unit, that will be upgraded for the updated 80 channel type in the near future. The main unit is mounted under the drivers seat, not in the picture is the microphone cradle which will sit on the centre dash console just below the radio.
    The rear seats came out quite easily with the PDF instructions from the Toyota service website, I reckon I had them out in 20 minutes tops
    I arranged all the cables in a neat loom, trying to keep it as factory looking as possible. I know it'll give me plenty of years of trouble free service
    The LED light can be rotated and serve the purpose of shining light onto the slide out table once it arrives
    The wiring loom comes into the jack compartment where it splits into its separate looms to be connected to the fuse box.
    Future mods for the Prado include:
    Foxwing awning
    Tracklander roofrack to fit the Oztent RV5
    Contemplating a Kaymar rear bar with Jerry can holders on the passenger side and spare on the drivers side.
    Kaymar rear wheel spacer and telescopic work light and HF radio mount
    ARB airlockers /Detroit E-Lockers front and rear
    Bilstien/Lovells suspension lift
    Chip it Diesel chip and egt monitor
    Maxxtrax
    Barret HF Radio
    Angry tyres either Cooper STT's or BFG Mud Terrain KM2's
    Of course there will be other mods, I don't think I ever stop tinkering in the pursuit of perfection..
    Thanks for looking guys.
    Chris.
    SOLD!!! 2011 Prado GXL manual in silver
    ARB Winchbar, Lightforce HID's, 3" SS Manta exhaust, 3" Monster Rides suspension system, Tracklander roofrack, Ostrich wing awning, Kaymar dual wheel carrier, Gturbo stage two Grunter and reprogrammed ECU. Trackabout Dakar SV Extenda. Purchased 2017 Landcruiser 200 Altitude.
    The site of the fuse box and all auxilliary connections. Note ABR charge gauge which I think is a nice touch
    Power outlets.
    Optima D34 marine deep cycle/start battery has proven reliable for the past 3 years in the Surf and looks like it'll dish out another few in the Prado. Note winch cables still to be terminated once the bracket for the solenoid box is mounted in position.
      50A circuit breaker controls power to the rear fuse box, I need to source larger terminal covers. There's sufficient room here to mount the winch control solenoid box on its side, I'll be doing this as soon as I get one of the fellas at work to fab the bracket up for me. The bracket will attach to one or two of the bolts on the inner guard.
      UHF mount. The main unit is located under the drivers seat. If I can find a way of mounting an external speaker and some gauges in a pod style arrangement it might be the next interior modification.
        Very pro looking set up mate, well done and keep i coming.
          Thanks MLC, its been great working on it, just taking it easy over the last few weekends, taking my time and making sure I get it right the first time.
            Looks great.
            [CENTER][SIZE=2][B][COLOR=blue][COLOR=blue]150 GXL 2009, T/D Auto [/COLOR][/COLOR][/B][/SIZE][/CENTER]
              Looking the goods there shamozzle. Keep up the pics, giving me some ideas for when my 150 arrives.
                Top job, love the mounting point for the ABR sidewinder battery monitor as well, gives we another job for a free weekend.
                Rogerthatv2
                Daniel
                  Originally posted by Rogerthatv2 View Post
                  Top job, love the mounting point for the ARB sidewinder battery monitor as well, gives we another job for a free weekend.
                  Thanks heaps. When I first started looking for ideas I paid particular attention to your build up thread Rog and got quite a bit out of it. Thanks for the ideas and keep watching this space in the future.
                    Just ordered the Chip-it + egt monitor, a set of Wild Ram sheepskin seat covers, some sandgrabba mats, some custom rocker switches and more cable for the rest of the accessories. The adrenalin is starting to build and I'm getting excited about finishing it off. Should have the Tracklander, suspension and tyres in a month or so as well, so we're really starting to cook
                      Sandgrabba mats installed and they do look the goods. Chip it installed and all good after a few teething problems. Tune set to level 4, but will be installing the fuel pressure override after this hangover subsides. Overall very impressed with the chip and how it has changed the dynamics of the vehicle, I really can't get over how much more responsive the motor is. Still waiting on replacement winch solenoid before I can finish that little project off and some custom rocker switches for the winch isolator and control. For now it's just a waiting game.
                        Hey Shamozzle
                        Your work looks great...my ammateur eye can hardly tell whats factory and what's been Shamozzled!!
                        Have u got some pics of the sandgrabba's I frequent fraser island WITH KIDS!! So I think it'd probably be worth my while getting some.
                        Question...I have a good quality auxilliary battery installed and they only put a single cigarette lighter outlet off it and an Anderson plug mounted in the back in above the jack in my 120. The ABR monitor is a great idea and more plugs would be good. Is it hard running the cables from the bonnet back to there? And what are the fuse boxes for? I don't have a great deal of elctrical knowledge but learn fast....I think?!
                        [COLOR="#000000"]2003 Grande, Maxtrax,ARB rear and side awning, Rhino rack, GME 3100 UHF, Sony 2DIN DVD/reverse camera, 2x 9" headrest DVD's + 2x 7" headrest DVD's, Aries sheepsking custom covers, 2" raised kings, ARB underbonnet high output compressor, Hybrid dual battery with fuse box and additional outlets in rear, Rear door table, High power reverse LED flood, Staun deflators, ARB snatch hitch and strap, PP sticker[/COLOR]!
                          G'day Brad,
                          I'll get some pics up of the sandgrabba mats as soon as I can. The fuse box in the back neatens things up in the engine bay. Instead of having a heap of fuses hanging off the terminals I've ran a single feed to the rear of the vehicle which is 25mm2 from memory, this minimises voltage drop, however 16mm2 will also be sufficient for most applications. The cable is protected by a 50 amp circuit breaker which should be sufficient to run all circuits needed. from here I've split the circuits from the fusebox so each circuit is protected by its own fuse. It isn't too difficult to run the extra cables you require to the auxiliary battery at the front of the car but bare in mind that long runs of thin gauge cable means that you'll suffer larger amounts of voltage drop at the other end and this is why I'd recommend splitting the circuits from a fusebox in the rear rear. Just remember also that the outlets are rated for 120w from memory so that's 10 amps. Another tip is to check behind any plastic trim if you plan drilling into it, just to make sure you're not going to damage anything that may be behind it. If you'd like any additional information send me a pm and I'll help out as much as I can.
                          Chris.
                            Thanks Chris
                            That should get me started. Probably next week after I finish my draws. Will pm u if I get stuck
                              As requested Brad here are some pics of the Sandgrabba mats installed. Pretty neat and much better than the old rubber mats I had previously.
                              Chris.
