If you grab the panel where the AC controls are and pull it out towards you, its held in there by 4 clips. Then unplug the cable in the rear.
Post #123 onwards is good for removing trims to access handbrake cable adjustment.
12mm spanner to adjust, if its never been adjusted the cable ay need a couple turns.
