Brains TD 150 GXL
Rob and others,Originally posted by gumboot View PostPaul,
The interior leds looked great the other night, can you send through the ebay link for them please if youstil have it.
The interior LED's I used were the same as these ones (48 SMD LED). I see there are a group of 5 for sale together with different vendors. Maybe get together and purchase as a group.
http://www.ebay.com.au/sch/i.html?_t...at=0&_from=R40
The in door LED's I used were similar to these. (12 SMD LED)
http://www.ebay.com.au/itm/Car-12-Le...ht_4495wt_1156
The Rear touch light on the rear door that I used is available from Springers.
It is a 12V touch light 600mm long and about $47, has an aluminium strip on the back you can bend to suit the profile of the trim.
Paul
Leave a comment:
Just trying to find them.Originally posted by gumboot View PostPaul,
It's the best cold coffee I've ever had, we had a 6 pack with us and it was great. Interesting concept too.Originally posted by gumboot View PostPaul
I also saw elsewhere you been trying Cleanskin Cold Press Latte.
What's your thoughts
I am going to need coffee at Fraswer Island next week!
Robert
Leave a comment:
Paul
I am going to need coffee at Fraser Island next week!
RobertLast edited by gumboot; 22-03-2013, 08:31 AM.
Leave a comment:
Paul,
Leave a comment:
Didn't get a chance was at cricket Saturday then Rugby League most of the day Sunday. I might have to try and get it done one day this week.Originally posted by fido666 View PostDid you remember to take any pics while pulling the dash apart Paul? I've ordered a Uniden UH7760NB UHF to replace my Icom unit so will be needing to pull the console apart myself soon.
Leave a comment:
Leave a comment:
Paul
Aside from re-soldering the internal wires on the monitor to make it +ve link, did you install a relay between the blue wire from the monitor and the blue wire of the SBi112 that was fused back to the ignition as per their docs?
Leave a comment:
There's my problem I keep missing "Wonday". Just looking ahead to the weekend and I've got cricket Saturday morning with the eldest and then Football Sunday morning with both boys playing at the same time in two different locations I'm going to have my work cut out for me.Originally posted by gumboot View PostThanks Paul,
Perfect, will get one ordered.
Yeah I already run a 60 amp breaker that feeds to the back power run and I can also cut off all power to the back , But I am planning a second dedicated run to the back for the inverter and looking for some smaller breaker options.
I just do all my outstanding jobs on "Wonday", that's right after Sunday and before Monday....
Cheerse same
Robert
Leave a comment:
Thanks Paul,
Robert
Leave a comment:
Robert,Originally posted by gumboot View PostBrains,
I have decided on one of these as well. Were the rewiring instructions with the unit?
I am changing my dual battery setup at the moment. Also I like how you have run those circuit breakers for the rear power runs.
Have to catch up for a look see when your free.
cheers
Robert
Here is the link for the rewiring instructions
http://www.mediafire.com/file/560js0...0the%20ABR.pdf
I wanted the ability to be able to turn the feed off to the back cargo area and the exterior Anderson so that is why I went with the breakers.
And yeah have to catch up, just need to organise 10 day week so I can fit everything in.
Paul
Leave a comment:
Brains,Originally posted by Brains View PostFor my Dual Battery setup I used one of Derek (ABR SIDEWINDER) dual battery monitor. As I have the Redarc SBi12 I had to modify and rewire the monitor as per Derek's instructions. The re wiring allows the link button to manually activate the solenoid so that you can start off the 2nd battery if required.
Then installed the battery monitor is a suitable position.
cheers
Robert
Leave a comment:
Ahr wish I knew that the start of the week craig when i ordered some stuff!Originally posted by craigm View PostEdit: Derek has them. and I can now see how the cable is fastened with the single grub screw (have to remember to ask for the PP discount!)
Good to know for the future but
Leave a comment:
Leave a comment:
