Originally posted by Brains
View Post
Brains TD 150 GXL
Fido,Originally posted by fido666 View PostNo probs Paul, I understand.
Got it done and took some photos
Firstly what the dash looks like
If you grab the panel where the AC controls are and pull it out towards you, its held in there by 4 clips. Then unplug the cable in the rear.
Now grab the left hand side silver panel with the seatbelt warning light from the top and pull this out towards you, unplug the wiring loom.
And do the same to the right hand side but there is no wiring to unplug.
Grab the lower panel with the 4WD selector and tractions control, diff lock and pull it out towards you.
Last edited by Brains; 31-03-2013, 03:00 PM.[SIZE=2]Black 2009 150 Series D4D GXL Prado, [B]TG150[/B] Transfer Case & Actuator Guard, TJM T13 bar, TJM 9.5lb Winch, Airtec Snorkel, TJM steel sidesteps and sidebars, TJM Underbody Protection, TJM XGS Gold Suspension, Tinted, ARB Fridge Freezer, Couplertec System, Foxwing Awning, 80AH Dual battery, 8" indash GPS, Wet Seat seatcovers, GME TX3540, TX3110 & TX680, [B][COLOR=#ff6633]Maxtrax[/COLOR][/B], Kaymar Dual Wheel Carrier, Breathers, Federal MT's.[/SIZE]
Now grab thesilver shroud at the base of the gear stick and pull it down (there is a clip holding it in position.
Unscrew the gear change knob. (you may wish to move the gear stick further back by pressing the shift lock and moving gear stick. MAKE SURE HAND BREAK IS ON)
Now grab the front of the lower console and pull up.
Now keep moving back towards the centre storage compartment popping the clips until it comes loose.
Once you get to here you can either manoeuvre the top of the console to gain access or unplug the wiring looms to gain further access.Last edited by Brains; 31-03-2013, 03:05 PM.[SIZE=2]Black 2009 150 Series D4D GXL Prado, [B]TG150[/B] Transfer Case & Actuator Guard, TJM T13 bar, TJM 9.5lb Winch, Airtec Snorkel, TJM steel sidesteps and sidebars, TJM Underbody Protection, TJM XGS Gold Suspension, Tinted, ARB Fridge Freezer, Couplertec System, Foxwing Awning, 80AH Dual battery, 8" indash GPS, Wet Seat seatcovers, GME TX3540, TX3110 & TX680, [B][COLOR=#ff6633]Maxtrax[/COLOR][/B], Kaymar Dual Wheel Carrier, Breathers, Federal MT's.[/SIZE]
Also check out our Straddie Video
http://youtu.be/MvVrqS0G9dc
To watch it on iPhone/ iPad or mobile device you can do it by going to this page.
http://www.4x4review.com.au/snaps.php?album_id=4 (this link is not working at the moment trying to get it fixed. If you copy and paste the address in your web browser it works)
Please share it with your friendsLast edited by Brains; 01-04-2013, 09:37 AM.[SIZE=2]Black 2009 150 Series D4D GXL Prado, [B]TG150[/B] Transfer Case & Actuator Guard, TJM T13 bar, TJM 9.5lb Winch, Airtec Snorkel, TJM steel sidesteps and sidebars, TJM Underbody Protection, TJM XGS Gold Suspension, Tinted, ARB Fridge Freezer, Couplertec System, Foxwing Awning, 80AH Dual battery, 8" indash GPS, Wet Seat seatcovers, GME TX3540, TX3110 & TX680, [B][COLOR=#ff6633]Maxtrax[/COLOR][/B], Kaymar Dual Wheel Carrier, Breathers, Federal MT's.[/SIZE]
Awesome Paul. I need to pull the 4wd selector panel out to fit the volt/volt meter. Do you remember how much space there is behind the fascia? I am looking to fit the Baintech gauge and it is quite deep about 50mm for the full 47mm diameter.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Michael,Originally posted by mjrandom View PostAwesome Paul. I need to pull the 4wd selector panel out to fit the volt/volt meter. Do you remember how much space there is behind the fascia? I am looking to fit the Baintech gauge and it is quite deep about 50mm for the full 47mm diameter.
If you check out the last photo in the post http://www.pradopoint.com/showthread...l=1#post400151 you can see that the 4WD selector goes back a bit, from memory it protrudes about 50mm into the cavity so there should be well and truelly enough room.
Paul[SIZE=2]Black 2009 150 Series D4D GXL Prado, [B]TG150[/B] Transfer Case & Actuator Guard, TJM T13 bar, TJM 9.5lb Winch, Airtec Snorkel, TJM steel sidesteps and sidebars, TJM Underbody Protection, TJM XGS Gold Suspension, Tinted, ARB Fridge Freezer, Couplertec System, Foxwing Awning, 80AH Dual battery, 8" indash GPS, Wet Seat seatcovers, GME TX3540, TX3110 & TX680, [B][COLOR=#ff6633]Maxtrax[/COLOR][/B], Kaymar Dual Wheel Carrier, Breathers, Federal MT's.[/SIZE]
Looks like there is a bit going on in there so I guess I just have to test fit the meter. Ta.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Got stuck in and did some more work on my Dual battery poer distribution in the rear cargo area.
I made up some Anderson Plugs that can be mounted flush on the side of the cargo area. I like the positive locking of the Anderson plugs and have also made some Anderson to other small cables so that it is a fairly Universal way of connecting just about anything.
I had already run a circuit breaker and a small fuse box in the cavity on the left side of the cargo area.
On the cover I had installed 2 of my Anderson Plugs, a 12V cigarette socket, Baintech dual USB socket and a Voltmeter with a push on/push off switch.
I did all the wiring in behind the panel ready to fit.
And then connected up all the positive cables to the small fuse box and the negatives to the negative stud.
I then put the associated fuses in the small fuse box and turned the power on, on the manual circuit breaker under the bonnet. And everything tested and works well.
Very neat! Anderson plugs are good value. For the smaller loads (up to 30A) i use their powerpoles. you can you buy from 2 to 8 gang outlets that are flush mount, i used a 6 gang on the back of my battery box. Where did you get the volt meter from? Do you have a link?My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
I just bought some powerpoles. They are a great product too.Originally posted by mjrandom View PostVery neat! Anderson plugs are good value. For the smaller loads (up to 30A) i use their powerpoles. you can you buy from 2 to 8 gang outlets that are flush mount, i used a 6 gang on the back of my battery box. Where did you get the volt meter from? Do you have a link?
Voltmeter was from eBay check out item number: 140794138836
Very expensive at $2.74 AUD delivered.[SIZE=2]Black 2009 150 Series D4D GXL Prado, [B]TG150[/B] Transfer Case & Actuator Guard, TJM T13 bar, TJM 9.5lb Winch, Airtec Snorkel, TJM steel sidesteps and sidebars, TJM Underbody Protection, TJM XGS Gold Suspension, Tinted, ARB Fridge Freezer, Couplertec System, Foxwing Awning, 80AH Dual battery, 8" indash GPS, Wet Seat seatcovers, GME TX3540, TX3110 & TX680, [B][COLOR=#ff6633]Maxtrax[/COLOR][/B], Kaymar Dual Wheel Carrier, Breathers, Federal MT's.[/SIZE]
Good job, well done.
Just something to consider as a suggestion to others thinking of the same sort of install. I mounted my anderson plug and 12v socket through the plastic hatch directly below the hatch used by Brains, its not used much, and it means you can keep the little upper storage compartment free to store odds and ends....I just peeled the sticker off the lower hatch cover and restuck it on the hatch above, and otehrwise, the install is very similar...just worth thinking about, because every little storage compartment can come in useful when travelling.Last edited by brogers; 31-03-2013, 09:46 PM.SE Qld: GX 150GD Auto, (Feb'16 build): TJM T15 steel b bar, 9,500lb TORQ winch, TJM s steps, Rhino Pioneer Platform (42102B 1928X1236mm), front recovery points, Wynnum towbar, P3 brake controller, TNN Underbody guards, UHF, TREKtable & LED striplight, Custom Fridge & Drawers, Waeco CFX50, 9inch illuminator 160W LED spots, 40mm lifted Dobinson Suspension (Zordo's), ScanguageII, 30 Sec Wing Awning
