What are you doing with the sheepskins? A quick recap of what your suspension setup is too please. I recall you changed the shocks and springs so I take it that knocked out the sport/comfort setting from the cabin. I'm just looking to lift my Kaka enough to cater for the bar and winch.
Daz's 2010 Kakadu is getting some lovin
Originally posted by Hutch View PostKaka r u selling the sand grabbers?
Hutch- 2012 Prado 150, some TJM Kit.2010 Kakadu with all the usual stuff.... Build up thread below
Originally posted by fido666 View PostWhat are you doing with the sheepskins? A quick recap of what your suspension setup is too please. I recall you changed the shocks and springs so I take it that knocked out the sport/comfort setting from the cabin. I'm just looking to lift my Kaka enough to cater for the bar and winch.2010 Kakadu with all the usual stuff.... Build up thread below
Originally posted by KAKADAZ View Postif I sell the bar I will sell the suspension which is Lovell front springs and bilstein shocks front and rear.
You will loose your comfort settings but the car ends up handling equivalent of the normal mode anyway. I will be selling the sheepies.
Its a Brown Davis bash plate as well not a craig Davies lol, the actuater gaurd that went on about 2 months ago will also be up for sale..2010 Kakadu with all the usual stuff.... Build up thread below
Originally posted by fido666 View PostHmmm, sheepskins, suspension, actuator guard; so much to choose from. And the prices of all these goodies?2010 Kakadu with all the usual stuff.... Build up thread below
Daz
Please forgive me but someone sent me a link and the first thought that came to mind was "Daz's rig getting some lovin" Its a good vid, but if your time challenged refer to 1 minute 20 seconds.
http://youtu.be/EKZ5LrUCpLQ
mlc - ............[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
mlc - ............2004 V6 Grande. BLACK -
Originally posted by JasenDaz you are a legend, that is gold. A 2" Kakadu lift for under $300 and you keep all the settings.
Just one question, is the airbag ok to be lifted an extra 2" when you hit the high setting?2010 Kakadu with all the usual stuff.... Build up thread below
mlc - ............2010 Kakadu with all the usual stuff.... Build up thread below
Originally posted by KAKADAZ View PostI would say yes it stretches more than 50mm at full drop anyway and the shocks will always be the limit.
The spacers fit between the self leveling sensors so the car thinks the car is carrying a caravan etc and pumps the bags up to re level the car but effectively go's 30-50mm higher than standard so nothing more than 20 odd flat washers and some longer bolts. The fronts need some 20mm spacers (check eBay) they mount at the top of the struts so that raises the body of the car 20mm off the standard suspension meaning no change to the standard suspension. Get a wheel alignment and presto.2010 Kakadu with all the usual stuff.... Build up thread below
