Matt's 150 GXL
  • Na Geoff. It's the route I used from the front diff. Going to tidy that up today.
    Caterpillar breathers are what I used.
    [CENTER][B][U]Matt
    [/CENTER]
    [SIZE=2]
    [/SIZE][CENTER][SIZE=2]
    [/SIZE][/CENTER]
    • Decided to relocate my fuel tank breather today. Not hard and worthwhile mod to do. I found even after a few months, mine was full of crud.
      New home is right up next to the fuel filler neck. Just need to strip out the passengers rear inner mud guard for access.
      Original spot -
      Pulled out and cleaned up -
      Ready to refit -
      New home up next to filler neck -
      [CENTER][B][U]Matt
      [/CENTER]
      [SIZE=2]
      [/SIZE][/CENTER]
      • Might do the same.....
        I did my rear diff breather the other day and ran it up into the same spot.
        Matt can you tell me if you have any special way of removing the clips from the inner rear tyre guard?
        The ones I am talking about are the Square ones with the "push in" tab's on the actually corners.
        I could not find any easy way to get them off beside trying to get some pliers behind the mudguard and try and access the tabs.
        Looks like their is a hole at the front that you may be able to push something into to intern move the tabs in...
        Know what I am talking about?
        Will get a photo in the next few days to make it clearer...
        Bernie
        • Sure do Bernie. They are standard Toyota square plugs and they suck. You are spot on with the pliers trick to remove them from the holes. I cheated and just removed the bottom one like this..
          To relocate my breather, I got my daughter to hold the plastic guard out of the way and I reached up and attached the new hose and modified breather set up. It's amazing where I can fit my hands on this new Prado.. I do enjoy a challenge
          [CENTER][B][U]Matt
          [/CENTER]
          [SIZE=2]
          [/SIZE][/CENTER]
          • Good stuff, nice tidy work. Just a word of caution. Make sure you secure that to the breathers to the fuel filler neck make sure you secure them nice and tight.
            Otherwise you might make the same mistake as me and make several trips into you toyota dealership demanding that they "fix that annoying rattle coming from somewhere in behind the back seats, this is unacceptable in a new car!!".
            then completely redfacepalm when they tell me that its been caused by the two breathers rattling against the fuel filler neckops: .
            150 VX diesel. Awesome bonnet protector! Monster Rides 3" Susp Lift, 265/70/17 MT MTZ's on Dick Cepek Torques, TJM T13 bar,TG150 Guard, Airtec Snorkel, Lightforce HID's, GME TX3540, CKMTA12 compressor, redarc dual bats, Drawers, fridgy drop slide, Maxtrax, More to come... one day!
            • Classic ! Yeah have a peek at the photos and I have wrapped the breather in rubber, to insulate any vibration or rattles..
              [CENTER][B][U]Matt
              [/CENTER]
              [SIZE=2]
              [/SIZE][/CENTER]
              • Had annoying noise from the drivers side A-pillar while driving to work in the mornings. But on the way home in the afternoon, the Ouse would be gone ? I managed to work out the sub zero temps we have had was contributing to the noise.. It was where the bracket for the snorkel was attached to the A-pillar on the outside of the car, there was a squeaky noise when I rocked the snorkel body about.
                That Arvo, when I got home i undid the two bolts that hold the snorkel too the body bracket. Then the next morning (again pretty cold about -2) I reset the bolts tight. Travelled to work, and noise all gone !
                [CENTER][B][U]Matt
                [/CENTER]
                [SIZE=2]
                [/SIZE][/CENTER]
                • Went for a lap up into the Barringtons this arvo in search of snow... to no avail. Peaked at a few tracks and found some old points I had lost from my GPS..
                  matt150
                  [CENTER][B][U]Matt
                  [/CENTER]
                  [SIZE=2]
                  [/SIZE][/CENTER]
                  • Change the rego and use this. Click image for larger version
                    Steve.
                    Stephen Bloomer
                    • Well the truck is going great. Even with a 250km return trip up into the Barringtons the other weekend. Averaging about 55kmph, which is start stop too and from work. Here's a couple of happy snaps..
                      [CENTER][B][U]Matt
                      [/CENTER]
                      [SIZE=2]
                      [/SIZE][/CENTER]
                      • I have had enough of the rattle in the passenger seat. I called into my dealer and he went for a lap and conceeded it was noisy. The seat is out for repairs and I am driving about with no seat.
                        [CENTER][B][U]Matt
                        [/CENTER]
                        [SIZE=2]
                        [/SIZE][/CENTER]
                        • RACE SPEC Matt
                          • Should also fix that annoying high pitched whine that comes from the front passenger seat.
                            • Are they going to reset your airbag warning light when you drop the car back in? Normally when you start a car with a seat removed the SRS system is disabled?
                              VXWesty
                              [SIZE=1]2011 Crystal Pearl VX D4D Auto, MT ATZ 4 Rib, Full River 105AH / Redarc SBi12 DBS (TJM Tray), CKMA12 Air Comp, Alpine INA-W910R - PDX-5 - Type-R Speakers, Engel MT60FP, Rhino Alloy Platform, Foxwing Awning, Rear 12V Cig and Engel Socket, ARB Deluxe Combi Bar, Safari Snorkel, LF 240 XGT's + HID Upgrade, HB3 (9005) HID Upgrade, Bilstein / Lovells 2" Lift Suspension, Chip-It, Alpine PKG-RSE2 Roof DVD Monitors, Maxtrax, GME TX3540 + AE409L, Avenger TDS 9.5, ARB UVP, ARB Protection Steps.
                              [/SIZE]
                              • Yes they said it would only take a few extra mins to reset it.
                                [CENTER][B][U]Matt
                                [/CENTER]
                                [SIZE=2]
                                [/SIZE][/CENTER]
