120 Prado Rear Bumper
  • 120 Prado Rear Bumper
    After much search I finally decided to build a rear bumper for my Prado.
    The bumper was made of 3mm plate and 6mm thick plate brackets.
    I had an opportunity to test my welding when the vehicles was hurled againts some rocks on the left side while trying to climb a rock face.
    The bumper wad dented but no welds broke. The bumper did move about 5mm which move me to relook my bracket design. If I had the plastic bumper there would have been more damage!
    your obviously pretty handy with a welder and a torch
      very nice mate, excellent finish in the rear bar. Whats that sitting over your spare wheel? a BBQ?
      Regards, Heath.
        nice .
        hisham
        [COLOR=blue]2006 VX ,5 Auto , currently Scan gauge II , Bonnet Guard ,wind deflectors,head lamp cover, dust deflector,insect net , Engel fridge,IPF fat boy,Hella FF300 lights,Toyota HD bars,BF 265/70 R17 A/T, Hella TPMS, K&N,OME 2",DBA , AirLift 1000 & Wirless Air control , ARB Comp,Safari Snorkel.[/COLOR]
        [URL="http://www.fuelly.com/driver/hisham/prado"][img]http://www.fuelly.com/smallsig-metric/52690.png[/img][/URL]
          Looks good, do you have any pictures of the mounting system? and what would you do differently if you had your time again?
            Wow! Nice work. I was wondering about a 'build it yourself' solution but wasn't sure what sort of engineering would be required if the tow hitch was integrated.
            2003 GX TD Prado, 245 Cooper ST, Bilstein + Ridepro suspension, Icom 4400 UHF, Dig Options Sat Nav, ARB Alloy rack, Foxwing awning, 2012 Tvan Marranji Camper Trailer.
              Thanks for the positive comments guys.....much appreciated!
              To answer your questions;
              Yes it is a BBQ on the rear tyre. I never leave home without it.
              Andrew, I do not have photos of the mounting system. It basically consist of 6mm steel plate bracket that bolts onto the chassis on either side of the vehicle (left & right side). The vehicle has nuts welded to the chassis (OEM done) that are about 100mm apart. So here I have a flat section of plate flush with the chassis. From here I have a vertical welded 6mm plate that runs to the sides of the bumber. This plate is also strengthened with a 20mm flat bar along the top section. The bumber again has two flat plates that are bolted to the bumber that is welded to the bracket.
              What would I do differently? The tow hitch bolts straight through the bumper into the existing tow hitch bolts welded onto the chassis (OEM welded). Although I have changed the original towbar arrangement to support the chassis, I would have preferred to have the 4 tow hitch bolts going right through the chassis with nuts on the towbar bracket that sits behind the chassis. This feels like a much stronger solution. I have done many recoveries and it seems as if the 4 tow hitch bolts are coping!
                Impressive! Bloody good job.
                PS more picks of the bbq please.
                  Saw the same bbq plate at Rosehill NSW show last month at a South African stand selling small campervans. Can't recall the company though.
                  [SIZE=1]Cheers Jim.
                  [/SIZE][COLOR=#0000cd]
                    Now that is a nice bar - All we need is to get it produced here, as I assume that freight from South Africa would be just a little costly.
                    ....... more to come .......
                      Herewith more detail on the BBQ.
                      It's made from 10mm square bar with an expanded metal mesh on top. There is a hole in the centre of the grid....this comes in hande if you carry your spare on top of a roof rack. The spare wheel bracket normally has the threaded bar/stud with which the wheel is tied down.
                      The BBQ sits nicely on the wheel. You make use of a strap to tie it down to the wheel. I have never lost it. Most camping in the bush does not have a BBQ area....so you make the fire and put the grid down - no need to search for rocks or bricks to keep the grid off the ground.
                      www.frontrunner.co.za
