Finally set up dual battery set up, has Redarc BCDC1240, AMP/VOLT Meter, 350w WAECO power inverter, Dual Cig plugs, LED strip lighting at back of Draw system with on off switch located on front of draws, LED torch and holder, Baintech Fuse Block, Dual USB charge plug, Anderson plug for Fridge, Happy days cold beer again!!!!!!!!!!!
Ryno78 150 GXL Dual Battery Set up
Finally set up dual battery set up, has Redarc BCDC1240, AMP/VOLT Meter, 350w WAECO power inverter, Dual Cig plugs, LED strip lighting at back of Draw system with on off switch located on front of draws, LED torch and holder, Baintech Fuse Block, Dual USB charge plug, Anderson plug for Fridge, Happy days cold beer again!!!!!!!!!!!Lightforce HIDs 240s x 2, 170HIDs x 4, Maxtrax x 4, roof mount lock pins, redarc BCDC 1240, Optima Yellow top, Baintec Volt/AMP meter, internal LED lighting, Drop down table, ARB47lt fridge, Drop slide, Black widow draws, WAECO 240v Converter, Wetseat seat covers, GME UHF aerial, iphone cradel n GME aerial, HEMA GPS, Tunit Chip, Couplertec Rust protection, OME suspention, Lukey performance exhaust, Rhino Black pioneer tray, BFG ATs allroundTags: None
