Thanks, the ARB 3/4 shackles I have don't fit.
Derek11's 2012 Blue Storm 150 GXL build up
Just had the 60000km service done, also got new pads put in and the discs skimmed. Fixed up the wiring to the rear ELocker last week. Ordered in from the USA 2 new UCA ball joints as the left hand one is worn, should have that here at the end of the month to replace.
Got Toyota service centre to check the injector feedback values and they were all nearly spot on, so I was pleased.
Just need to order Ozbush fuel mapper next month when he has the connectors to make it fully plug and play.
Only 10 more weeks left in Tassie then back to the mainland, get some stuff sorted in SA then off we go around the mainland.
Cheers DerekBlue Storm 150 GXL 4D4 PRADO and 2014 Cub Brumby Camper
My rig build [url]http://www.pradopoint.com/showthread.php?25698-Derek11-s-2012-Blue-Storm-150-GXL-build-up[/url]
whats the fuel mapper all about Derek?Originally posted by derek11 View PostJust had the 60000km service done, also got new pads put in and the discs skimmed. Fixed up the wiring to the rear ELocker last week. Ordered in from the USA 2 new UCA ball joints as the left hand one is worn, should have that here at the end of the month to replace.
Cheers Derek2015 KDJ150 GXL.
Just replaced the left hand UCA balljoint as the old one had movement, the right hand side is OK but got a spare incase it goes as well.Blue Storm 150 GXL 4D4 PRADO and 2014 Cub Brumby Camper
Hey Derek, how did your trip around mainland Australia go?2012 150 Altitude 4.0L V6 - ARB deluxe winch bar, Old Man Emu 2" suspension lift, FJ Cruiser wheels (17 x 7.5J ET15), Toyo AT2 LT245/75R17, Safari Snorkel, K & N air filter (33-2438), ERPS 6-coupler, Toyota towbar (2500kgs), ARB front rated recovery points (8000kgs), Bushranger recovery hitch + 4.75T shackle (WLL 5000kgs), ARB under vehicle protection, Brains actuator/transfer case guard, GME TX670, GME 3550s, Kaymar rear bar
