Originally posted by SOL
View Post
SOL's 150 shorty SX.
Originally posted by fido666 View PostCan you take a photo of how they have mounted them to the chassis/bullbar? I know you have an ARB bar, just interested to see which mounting holes they have used.
SOL.[COLOR="#006400"][url]http://www.pradopoint.com/showthread.php?26339-SOL-s-150-shorty-SX[/url][/COLOR]
Originally posted by SOL View PostFido mate post 131 updated. Hope they help?
[QUOTE=fido666;411680]It's a good thing your 1st initial isn't R ;-)[/QUOTE
Very funny. Never thought of it. But I get called it a lot..
[ATTACH=CONFIG]11157[/ATTACH]
SOL.
Im pretty sure they should be atleast 8.8 minimum, ideally 12.9.
I do know one of the gurus on here will correct me if im wrong! :-)Geoff
Originally posted by BrettM View PostGeoffury it's says 5000kg so good for 5 ton each, 10 ton off both. Nice shorty by the way SOL if I ever get another Prado I think it will be a shortyGeoff
Originally posted by Geoffury View PostHey Sol, it might just be my really bad eyes, but in the last pics of your recovery points, is the bolt stamped 4.6 as its rating?
Geoff is right, don't use the points until you change the bolts out.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by mjrandom View PostGeoff is right, don't use the points until you change the bolts out.
I am not sure what the bolt heads should have had.
Looks like I am going back to Opposite lock to get them to have a look.
Originally posted by Foxy48 View PostIt is just sooo good to see the shorty getting some respect at last .People have had a go at mine asking where the rest of the car is then I tell them what they are missing out on .Just great, Sol, I too am a ex digger (Vietnam) Cheers Mate Foxy
Thanks for the reply. Do you have a rig build? I love the shorty. Screws with so many people when you talk to them about a two door Prado.
My service was not that great I was only a chock for about 8 years. But spent the last 15 years supporting the ADF in their efforts.
Mate, All good ,Yes I have done a bit. I have added a extra oil cooler and a K&N oil filter (Extra) equiv to a Z9. Added gauges ie Trans temp and engine oil pressure, engine oil temp as I like to see something going wrong before it actually happens .Also a 460 Racor fuel filter 10micron with a water bowl as the OE is 2 micron. I change them at 20k now every 40K including the fuel tank . I have fitted a catch can and also a bypass engine oil filter system having moved the engine oil filter to the chassis and it is well protected .A Piranha duel battery system and added extra outlets in the rear for whatever the need .I'm slowly changing my exhaust to 3" with a high flow exhaust only , added 275x65x17 tyres, a GME remote head UHF radio, a caravan braking system a T some thing or rather, Haymen Reese tow bar I can actually see the ball when reversing . My dreams were a long range tank a better suspension as the rocking bugs me at times . but I'm still working towards a snorkel .
Mate thank you for serving .It does not matter in what role we play as we all work together for one goal and that is for this beautiful and great country to be able to do what we do with peace and freedom but we need to look after it and not take it for granted because we will not realize what we had until we have lost it. Cheers Mate God bless Foxy PS I will be following you from now on
