VeeZeeSS's 2012 VX D4D
  • #61
    Looking good, the lights on the rear of the platform is one of the next on my to do list, also maybe an led strip down the side under the awning, jury Is still out on that one...
    Cheers JPH
    150 with stuff bolted on!
    • #62
      Cheers JPH
      Really pleased I installed the LED strip in my awning with the wireless remote dimmer.
      Great for camping
      • #63
        Craig,
        What lights did you end up using for your awning lights? Are they hard wired?
        Robert
        [B]Robert
        • #64
          Can't remember Robert, it was a while back now. I'm pretty sure it was the 60leds/m waterproof 5050 smd in a 5m roll. I haven't hardwired it. What I did do was buy from Jaycar some mono audio jacks to use as plugs and in the top pic you can see the plug tail sitting there. All I do is plug into my accessories plug in the rear and poke the lead out through the side glass to plug in when required. (dont think the 150's have an opening side glass?)
          • #65
            Few pix of the car after a run up a mountain yesterday...
            2012 Pearl White VX, 3.0 Litre D4D Auto, Wynnum 2.5T Tow Bar, OME Lift, TJM Airtech snorkle, TJM diff breathers, Redarc EBRH, Projecta DBC100K, Lightforce XGT, EBC Nudge bar, Custom Recovery Points, TG150, ARB compressor, Pioneer Platform, Kaymar #K7123 /CDQ2195, 697 A/T's, Tin's DC trans cooler, MaxTrax on TraxRax, TJM DBS, Piranha Tray...
            • #66
              Decided I'm going to move the compressor to the rear of the engine bay on the driver side in the below space...
              This will allow room for a 2nd battery (once I decide on the best battery tray to use).
              • #67
                Have a look at my build, there should be some shots on how I've mounted mine there. It's tight but does the job! The bracket was nice and easy to make, let me know if you need anything else.
                http://www.pradopoint.com/showthread...-JPH-s-150-GXL
                This should link to it.
                Josh
                JPH
                • #68
                  Well, couldn't help myself and got an awning ready for our beach run at Christmas time...
                  Fitted up in 10 min and has made no additional wind noise while driving
                  • #69
                    Few pix taken over Christmas...Awning was used everyday and was worth every cent !
                    • #70
                      Originally posted by VeeZeeSS View Post
                      Finally got my custom mounting pod completed for my phone carkit cradle.
                      Its a fiberglass pod covered in black leather.
                      How is that mounted befind the cradle?
                      Is there another bracket? or didi you glue / drill the panel?
                      Robert
                      [B]Robert
                      • #71
                        Hi Rob,
                        Made up a fibreglass pod to screw the cradle mount to. We then screwed this to the panel (centre speaker panel) as this will be the cheapest to replace at a later date if required.
                        VZ
                        • #72
                          finally received my luggage hooks...
                          Made a few small cutouts in the rubber mat and now the fridge now stays still when I'm off the beaten track
                          • #73
                            So far so good... Everything within spec
                            Few too many kms in under 2 years but I love driving it.
                            • #74
                              Clocked over and just had the 120K service. I must say the auto is running 15-20 degrees cooler with the Davis Craig unit sitting on Tin's brackets. Should of done this 120,000 kms ago.
                              • #75
                                Helps when towing this too
