Love the light strip under the awning, looks like and bright. Where did you order the LED's from?
amts' 120 Grande V6
Originally posted by Gramps View PostLove the light strip under the awning, looks like and bright. Where did you order the LED's from?
So far on the awning, there are no problems. It gets left on for maybe 2 hours at a time. Perhaps being glued to the aluminium extrusion of the awning and the fact that it was cool when we went camping probably helps with heat dissipation.
Moved the QuickFists (aka shovel mount) under the Pioneer Platform for more clearance into underground carparks.
Andrew be careful of the rubber strips if they have been in the sun I have had one of these fail and a few of the other Rhino style. I now use occy straps and I throw a couple of cable ties over the shovel. Might be our overly aggressive ultra violents up hereMy 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Fitted an organiser tray for the center console fridge. It's a perfect fit with a fairly deepish tray.
Separate thread here http://www.pradopoint.com.au/showthr...912#post568912
