DJ D's D4D 120 GXL
  • DJ D's D4D 120 GXL
    So here is my Rig.
    So far I have done:
    ARB Deluxe Bar
    Warn Tabor 10K Winch
    Warn Recovery Kit
    Safari Snorkel
    GME Uhf
    BFG AT LT 265 70 17's
    Lightforce Spotties
    Eclipse Sat Nav
    Waeco CF40 Fridge
    Optimat D27 Aux Battery
    Redarc Sbi12
    Leigh W Diode
    Dual DIY Voltmeters
    Rhino Roof Platform
    ARB Compressor on board
    DIY Trek Table
    DIY Drawers
    DIY Electrical system and switches
    Hilux Jets
    Breathers
    Water Pump
    Camp Light
    LEDs for awning, cargo barrier and RTT
    ARB Roof Top Tent, Annex, Awning
    Maxtrax (black)
    Hi-Lift Jack
    Shovel
    22' LED Light bar
    2" Lift with Dobinson coils and Bilstein US Shocks
    AMTS radiator Plate
    AMTS Dif drop kit (not installed)
    plan to do:
    Rear Locker
    Exhaust
    Chip
    from first post....
    Here she is, already a bit dirty, the way it should be
    120 GXL, D4D Auto 2007
    She came with a Sovereign Bar, Snorkel, GME UHF, BFG AT's, Lightforce Genesis Lights and an Eclipse touchscreen Sat nav/Audio system. I went for the few extra's instead of low K's figured I wont have much in change for mods. (its amazing how you find $$ for them though)
    For my first mod I thought I would start with the dual battery install, still waiting on some parts to arrive but I got the tray in and started to clean up some lose electrics in the engine bay from the previous owner. looks like they took their dual battery when they sold it!
    Battery Tray in: drivers side front - Piranha tray
    Will post some more pics of my battery install and the compressor install soon after! (starting small)
    I have just sold my Bike so it looks like a deluxe bar and maybe a winch are not too far off.
    thanks for all the threads so far its made for good reading and education!
    Cheers!
    DJD120GXL
    Next up I decided to take on the compressor install, it looked reasonably easy and I have a bit of electronic/soldering experience so I thought I would give it a go.
    unpacked the kit and checked all the terminals for where they go and started to mount the compressor
    decided on the far right near fuse box and started to mark it out. As there was a slight level difference I mounted 2 bolts to a flat surface and used some rubber grommets to space for the lower 2
    Feed the control loom through thru firewall to the drivers side switch/fuse box.
    I found using a plastic or plasitc coated coat-hanger with the loop taped to it got the job done.
    used some protective felt, its the stuff you can use on table legs to protect floors with one sticky side. this helped to even out the balance and give it some padding.
      connected the loom to the switch mounted near the driver door.
      Checked the plate for the balance and the holes lined up fine
      rubber boots on the bottom 2 bolts
        Bolted the compressor in and tightened under wheel arch
        connected up the loom to the switch
        Spliced into the ACC power
        Added a fuse as per (LiveFreeAndRoam's) install thread thanks!
        DJD120GXL
          Looking good djd. What are your plans for further mods? It's ok you can tell us, wives don't visit here... Except a few but they are as passionate as anyone about their Prado.
          Keep up the good work.
            Mounted the compressor
            Getting a bit cramped here now!
            The switch installed
            All done! works a treat.
              Good work, thanks for the write up!
              Bernie
                thanks mj, ive just done the SBi12 install and dual battery setup so I'll post some pics soon, but otherwise I'm getting the ARB Deluxe bar installed late next month. that should give me enough time to save some coin for a winch. Im thinking about attempting that DIY, wish me luck!
                otherwise I would like to get/do:
                2" lift but don't have a clue about suspension
                front and rear lockers
                Chip (not sure)
                Exhaust
                DIY rear table
                Roofrack with rooftop tent and awning
                camp light
                better/darker tint
                Maxxtraxs, Jack etc
                but probably done in reverse order due to funds!
                DJD120GXL
                  One spot left for the Locker switch!
                    hahah exactly! the top too will go, so plenty of spots, middle top became override switch, far right is driving lights.
                      Dual Battery and Voltmeters Install
                      I got the Dual Battery system in over the last few days and I'm really happy its in and working.
                      I may have bitten off a bit more than I could chew with the voltmeters but it all worked out in the end, I started the night before with the center console on the kitchen table (mrs was at work) as the cables to the voltmeters were really short so I decided to terminate them then so I could just clip it all in the next day.
                      Getting it all ready and finding a location close to the start battery, its getting a bit cosy on that side of the engine bay!
                      used a coat-hanger to poke thought the cables for the meters and override switch.
                      ran the cables under the glove box and into the center console
                      then is was time to make sense of the spagetti
                        connected up the volt-meters to the cable runs to each battery
                        Took the power from the 12V which was also powering the UHF, in hindsight this was not the best as I would like to read the meters when the car is off, might change it down the track.
                        Cable tied' all the loose stuff out of the way of the gearstick and such
                        Voltmeters and override swicth + LED
                          decided to put the Isolator here, it just fits under the bonnet and is close to the battery and out of direct heat
                          went for the optima and ran power to the rear and middle of the car for fridge and inverter
                          Close up of the mount
                          The final product!
                            Nice work DJD - I like what you have done with the volt meters. Where did you get them from?
                              Thanks Smithy
                              I got them from this seller, but In red.
                              http://www.ebay.com.au/itm/DIGITAL-D...item4ac06d19cb
