Cheers Andrew, I'll try those settings
craigm’s 2004 Black 120 V6 Grande
Originally posted by craigm View PostTPMS Installed and running. Still unsure what thresholds I should set with regards to High/Low pressures and Temp. I'll have to have a bit of a play. Got a big drive on Sunday as we'll see how it goes.
Looks excellent Craig.
Forgive my ignorance, but does it read the pressure wirelessly from something you screw on the valve or do you have to have a sensor installed inside the tyre?
Jeff[SIZE=3]Jeff[/SIZE]
The Tyredogs (well this model anyway) use external sensors screwed onto the valves Jeff.
Thats excellent Craig, I might have to look at this myself.
Was it expensive and where did you get it?[SIZE=3]Jeff[/SIZE]
Originally posted by Jeffers View PostThats excellent Craig, I might have to look at this myself.
http://www.ebay.com.au/itm/130978497347?ssPageName=STRK:null:IT2004 V6 Grande. BLACK -
The Grande sitting up on Lovers Hill at the Springs 4x4 Park last weekend.
Nice beastie.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
LCMP Antics!!!
Following some more-than-enthusiastic water crossings at LCMP last weekend, the Prado developed a whining noise at the front of the engine.
Nothing visible could be seen and at first I thought it may have been fan damage, but listening more carefully it sounded more like the alternator. I was unsure whether the force of the water had pushed debris into the alt scouring the stator or dislodging the brushes. The drive home had me listening to the noise all the way home. It sounded a bit like the whine of a supercharger (I wish!!!) As the Prado is SWMBO's daily drive, she wasn't keen on driving it with the noise so I made a few calls on the Monday after being quoted $780 for a genuine replacement alternator which was Ex Sydney and was given a referral by a mate of a good Auto electrician (turns out he's a Prado owner too! and was good enough to cancel a couple of appointments and he headed over. With his long screw driver, the diagnosis was worn out alternator bearings, so he pulled it out and took it back to his workshop. Before replacing the bearings he spun up the alternator and although the bearings were noisy, it was not the sole cause of the noise, so after taking the alternator apart and replacing the front and rear bearings and checking the condition of the rest of the alternator, returned to remove and check on the tensioner and idler pulleys. It was found that the bearings on the tensioner and No1 idler pulley was also stuffed, so they were both replaced with new items.
Total cost... much less than the price of a new alternator, which I dare say, had I taken to Toyota to repair, would've cost me that and some more...
So if anyone requires a good Auto Electrician on the Sthside of Brisbane, send me a PM and I'm more than happy to recommend Gordon who was a champion!2004 V6 Grande. BLACK -
Glad to hear it wasn't anyting more serious Craig.Dan
Auto lekky reckons it was unrelated to the water crossings and that it was coincidental being more likely that the bearings were on their way out and the long days driving and conditions put them over the edge.. I beg to differ but that's what I told SWMBO and she bought it....
Glad you got if fixed alright Craig, it did sound like a supercharger under the bonnet....
The dreaded Petrol Prado Achilies heel strikes again....
[B]Robert
