Grims 2009 120 GXL
  • Grims 2009 120 GXL
    Picked up the Prado a couple of weeks ago now had 161k on the clock, ex mine car.
    Looked in good condition, has a roll cage inside, (so no third row) it may get removed but staying for now.
    had some slight corrosion on all the underbody and drivers window was smashed at some point and the replacement has different tint! (have to sort this out)
    first weekend down to the beach along with my mates hilux
    Had a good look over it and got full body rust protection done to it by the guys at Downey st rustproofing Bris, took them 2 days to clean all the mud out as a rubber grommet was missing from a wheel arch (cost $2 at Toyota spares to get another) and had filled up with mud! but the underbody looks great now!
    Picked up some rubber mats all round
    Fitted a GME uhf and aerial last week and removed some left over cabling from a sat phone, but the have left an extra handy fuse holder and power lines which made the radio install a breeze.
    Removed the roof rails and after long consideration fitted a Tigerz11 steel flat roof rack this weekend, I have read a lot about them and took on all the advice I found. I cut off the mesh as I didn't want it and it was so thin anyway, welded on some brackets for the awning that I am fitting this week and painted the whole lot, A big thanks to other users that spent the time to write up the install woes with these racks, it made fitting easy if still a couple of hours.
    Things done!
    Bat awning has been fitted with some custom mounts
    heated shower pump system
    Rock armour rock slider side steps
    air compressor ( in a toolbox) ARB
    Water tank, (long ranger 21L !) still to be fitted
    Wish List
    DIY rear swing door drop down table (thanks for the instructions!)
    LED light bar
    dual batteries (unsure, dont have a fridge yet anyway)
    suspension and lift kit
    bullbar and winch or maybe just winch and custom fitting
    air lockers
    2009 GXL 120 Series [URL="http://www.pradopoint.com/showthread.php?28535-Grims-2009-120-GXL"]Grims Rig Build Up[/URL]
    Hey Grim Welcome the guys at Downey street do a great job, they cleaned my car up on a few occssions...
    Hutch- Prado 2012 petrol with the TJM Catologue.
    [b]Rob[/b]
      Originally posted by Grim View Post
      Things to come!
      DIY rear swing door drop down table (have to find the thread on PP again for the instructions!)
      air compressor (under bonnet or in a toolbox/bag) still undecided
      LED light bar
      wish list
      bullbar and winch
      air lockers
      Hi Grim, good to see another 120 build on here (the 150s are constantly growing in numbers).
      For my 2 cents worth, I would definately recommend putting the compressor under the bonnet - You'll need it for air lockers anyway, and you will never leave home without it. Also, I would recommend the 2nd battery as it will make accessorising so much easier, you will have a battery to jump start yourself if needed, and after using a fridge for camping, you will never go back to eskys.
      The rear table thread is: http://www.pradopoint.com/showthread...ear-door-table and I think my wife is more excited about using ours for the first time than I am!
        Thanks Hutch the guys at Downey st were great, worth the extra drive for me (Im on the gold coast)
        and Smithy thanks for the warm welcome and for the thread link, might be next weekends project!
        Still not sure about the compressor, even if its under the bonnet you need a bag with your air hose somewhere in the car, but your right if I splurge on the air lockers ill need it there anyway!
          I keep my hose and fittings (still in the ARB box) under the passenger seat. Out of the way, but easily accessed, if that helps.
            Top bus, welcome to the never ending desire to "do just that little bit more".
              Welcome Grim
              Always cool to see another Prado get the "Hamburger with the lot treatment"
              Troy
                awning install complete
                Eezi-awn bat 270 awning from http://www.4x4awnings.com.au/ but they don't normally stock them, they are from South Africa http://www.eezi-awn.co.za/
                  Nice looking truck mate, love that awning.
                  [B][COLOR="#0000CD"][SIZE=3]Cheers Steve VK2UD
                  2007 turbo diesel GXL 120[/SIZE][/COLOR][/B]
                  [url]http://www.pradopoint.com/showthread.php?28546-Mudducks-new-toy-a-2007-120[/url]
                    Was a big weekend fitted my hot water shower and rock armor side steps pics to come.
                    My long ranger 21L tank arrived too but ran out of time to fit it yet
                      Rock armour side steps pics (click for larger image)
                      this top bolt hole had to be drilled. not sure if anyone else has had to do this?
                      the rest fit on perfect.
                        Here is some rack pictures of the tigerz11 steel flat rack with the mesh cut off and my custom awning mounts welded on.
                        there is 2 sleeves welded on that the awning slides into and then is bolted down.
                        solid and easy to put on / off by myself
                          Roll cage pictures
                            hot water shower kit install
                            http://www.helton.com.au/shop/item/hot-water-system-kit
                            Changed the fittings to standard hose fittings and mounted a custom bracket that I can reach under the front bar
                            Now to install my 21L long ranger tank!
