Bought this gem brand new in July 2000 and it is still going strong and no plans to change.
It's a 3lt Diesel and came with alloy rims, a sub tank, sunroof and CD Stacker.
Have slowly been updating bits and pieces along the way so here is the list:
- 2" Suspension lift
Washed and dressed down for the city
http://www.flickr.com/photos/100141355@N07/9489891535/
- ECB Big Tube Alloy Winch Bar
- Tigerz11 12,000LB winch with synthetic rope
- Lightforce Genesis Spotties with 70w HID kit
Winch is behind the number plate and the control box is in the ECB Bar
http://www.flickr.com/photos/100141355@N07/9489976429/
- Replaced the original headlights with after market ones
http://www.flickr.com/photos/100141355@N07/9490167243/
- GME TX3400 UHF Radio (old 40CH so needs an upgrade but will do for now)
The head is mounted just in front of the sunroof switches
http://www.flickr.com/photos/100141355@N07/9527714861/
The base is mounted in the centre console and held firm with a couple of cable ties. It has not moved in years.
http://www.flickr.com/photos/100141355@N07/9530502360/
- Triple gauge dash pod with:
- - - VDO Oil Pressure
- - - Autron Dual Battery and amp gauge
- - - VDO Air Pressure gauge (not yet connected)
http://www.flickr.com/photos/100141355@N07/9492964898/
- Inawise TPMS-201 (tire monitor)
http://www.flickr.com/photos/100141355@N07/9492964888/
- Removed factory CD/Radio stacker and replaced with Alpine CDE-103 and bank of 7 switches (2 still need to be connected)
http://www.flickr.com/photos/100141355@N07/9527719497/
- Made some Recovery points for the front out of 10mm Structural Angle Iron
http://www.flickr.com/photos/100141355@N07/9493181304/
- BushSkinz front bash plate
http://www.flickr.com/photos/100141355@N07/9490383695/
- Taipan 3" exhaust
- DP Chip
- Safari Snorkel
- Coopers Discoverer S/T MAXX tires
- ARB Air compressor (mounted in engine bay)
- Extended front and back diff breathers into the engine bay
- Extend gearbox/transfer case breathers into engine bay
- REDARC dual battery system (200A Relay) with Optima batteries
- LED Work lights mounted on rear wheel
- MCC rear wheel carrier (no carriers as yet)
http://www.flickr.com/photos/100141355@N07/9489976517/
- Replaced nearly every globe with LEDs
- Replaced rear light assemblies with after market ones that have LED Stop, Parking lights, Reverse globes are LED and they have an indicator lamp in the top section that now works.
http://www.flickr.com/photos/100141355@N07/9492963984/
- Built set of draws for the back
- Installed a pair of AJ120 Sliders
- Added a 22" LED Bar on the bull bar
- Replaced old rear shockers with 90 series Koni
- Install a custom towbar to fit with MCC wheel carrier
- Installed front and rear eLockers
- Rhino Platform roof rack
- Roof Top Tent
- Duel Jerry Can arm and Spare Wheel arm for MCC rear bumper bar
- Custom frame for MaxTrax on Rear wheel carrier
- Taipan 3" exhaust
- DP Chip
- Safari Snorkel
- Roof Top Tent
