Spilsy's 2013 White GXL Build Up
  • So, this arrived today (Note this is a "BFGoodrich Edition" - no idea what is different...):
    I think I will install it in the engine bay, where a 2nd battery would usually go (seeing as my 2nd battery is in the rear). Thoughts??
    Spilsy
    Spilsy
    • Mate check out AMT's bracket. It tucks the compressor neatly away at the rear passenger side of the engine bay.
      Nothing wrong with drivers side in front of headlight too of course.
      Micheal.
        Have been contemplating the bracket. I have to check how it fits with my VSR and CB for my 2nd battery.
        Spilsy
        • Has anyone ever taken the toolbox mounted compressor and made it an under bonnet compressor? How'd you do it?
          Spilsy
          • You would need to get Part no 320101 from ARB which is item 22 in https://www.arb.com.au/assets/air-lockers/3-04.pdffor $30.88
              I'm wondering if I can drill out the rivets holding the compressor mounting plate to the toolbox and transfer that straight into the engine bay.
              Not sure if the switch will survive living under the bonnet. I can move that though.
              Spilsy
              Spilsy
              • You should be able to remove the compressor from the blue sleeve, mount the backing plate to the second battery platform and slide the compressor back in.
                  Compressor is out of its sleeve. Had to take off the air filter to get it out.
                  Have removed the hard mounted hose. Will need to get some fittings to make the hose removable.
                  Spilsy
                  Spilsy
                  • Originally posted by Spilsy View Post
                    The compressor is in. I bolted the toolbox bracket to the 2nd battery tray using 2 of the M8 tapped holes. Hopefully 2 is enough, it's a bit tricky to pick up any more.
                    I have used some nitto fittings on both the compressor and the air hose. Not sure what the ARB fittings are...?
                    Spilsy
                    • I mounted my compressor up near the fuel filter using my own aluminium bracket utilising all factory bolts.
                      I just removed the compressor from the box and drilled the rivet holes out larger and bolted to my bracket.
                      The ally bracket is bolted to the inner guard and also braced back to the firewall.
                      It has been mounted here for a couple of years with no problems so far.
                      Hope this helps.👍
                      • Thanks for the info. I just had to create a new hole on the bracket for bolt 2. I drilled out another of the holes for bolt 1.
                        What have you used to cover the air outlet?
                        How have the electrics (particularly the switch) handled life in the engine bay?
                        Also, what did you do to the end of the hose? I've kept the 90° elbow and added a nitto male fitting
                        Spilsy
                        • Originally I used a rubber chair leg floor protector ,but a mate gave me the silicone cover I have now I think you will find them on eBay possibly.
                          As the compressor is mounted quite high and near the rear of the engine bay no problems so far.
                          I utilised the existing wiring and fuse that came with the compressor.
                          I just pop the bonnet plug in the orange air line supplied with the kit and turn on the switch.
                          You just need to be careful removing after airing up as the fitting gets quite hot.
                          • Just ordered the ARB inflator off Amazon. Delivered cheaper than any Australian retailer.
                            Spilsy
                            • UVP from Bushskinz arrived today... They are heavy! Now to work out how to install...
                              Spilsy
                              • I just installed my Bushskinz yesterday. Rear plate first, with the largest spacers and longest bolts to the front.
                                2016 Crystal Pearl Auto VX 2.8, TJM Bar, Safari Snorkel, Cooper AT/3, OME 50mm lift, Dual batts
