Bent front sway bar links
I was just putting the bash plates back on after installing my diff drop spacers and noticed the drivers side sway bar link was bent Glad I found it before it got any worse. I pulled the sway bar out tonight and will try and straighten it at work tomorrow, Fingers crossed.
I am also thinking about shortening the front links. From what I can see shortening by approximately 20-30mm would help return the sway bar to a more horizontal position. I have checked clearance and could see no issues with a reduction in link length. Since I have a bent link i was thinking about cutting it and shortening it, I was going to make a sleeve to go over the join and weld it into position to restore the strength.
