Tin175's White GXL 150 build
  • #31
    Wow! Tin
    Impressive custom step, tray and cargo barrier
    Do you do this sort of thing as a day job or are you a very skilled hobbiest?
    [LIST][*]Took a Prado half way around Australia in 2005 [*]Moved to Canada in 2007 [*]Coming back to Oz in 2015 to do the other half [*]Looking to buy a good used Prado and some gear [*]Hints on Sydney - Melb. - Adel. - Perth - Darwin with cheap accommodation appreciated [/LIST]
    • #32
      Originally posted by Canaust View Post
      Wow! Tin
      I do similar stuff in my day job so have access to laser cutting, fabrication and machining. So if I can't buy what I want have the means to design it and make it. I have a couple of other things that are on the drawing board too. I want to do something about water storage and a better way to carry bikes for the kids.
      • #33
        Transmission Guard
        I've got a Minecorp bash guard that I'm pretty happy with. They don't do a transmission guard so I got under the car and designed one up.
        Test fitted it before getting it powder coated. I will leave it in place for a trip on the weekend.
        Its made of 3mm pressed steel and has access holes to drain the auto tranny.
        • #34
          Hi, do u have any instructions or measurements, love to make one, great idea!
          Originally posted by Tin175 View Post
          I made up another cargo barrier as the first one didn't fit too well and I wanted to make it easier to remove. I also need
          to give more clearance around the air vents.
          The barrier is now a bit thicker and stiffer and can be removed easily without playing with the head rests. I also made cutouts in the top brackets so that the handles could be re-fitted properly.
          I installed an extinguisher. I'll probably look for a smaller one.
          Pretty happy with it now. Thinking to get it powder coated in a grey tone similar to the trim so that it blends in.
          • #35
            Tin175 has them for sale mate:
            http://www.pradopoint.com/showthread...go-Pet-Barrier
            • #36
              Originally posted by kenny5000 View Post
              Thanks kenny, does he do one for a 120 prado?
              • #37
                Hi tin, do u make a cargo barrier for a prado 120 series?
                • #38
                  I have a prototype in the works. Will be doing a test fit next week and will take orders once all is good.
                  • #39
                    Need a 120 to fit it up too???
                    • #40
                      Great tin! Looking forward to seeing it
                      • #41
                        Hi Tin,
                        Still interested in the cargo barrier for the 120
                        Pierre
                        • #42
                          That's a cheap bash plate tin, was that a special?
                          • #43
                            Quick Release Awning
                            I installed my Rhino Rack sunseeker 2 Awning. I have resisted cause I didn't really want to have something hanging on the side of the roof rack all the time.
                            I made up some brackets and slot nuts which allows me to remove the awning without any tools. Added another couple of brackets on the back and now I can easily move the whole awning to the back to cover the rear door area.
                            Made it so that it all sits flush with the top of the rack. Having the awning out the back is more useful cause that's where the fridge, drawers and table are. I can also easily position it off to one side. Awning is a 2.5m x 2m
                            And when I don't need it I can easily remove it and just leave the brackets bolted to the roof racks.
                            • #44
                              Maybe you need to sell these brackets , I would be interested in some
                              • #45
                                There are a few little changes I'd like to make so that it is easier to attach. Mainly a bit more clearance.
                                I'll then see what it cost for a batch and see if there is any interest.
