Joey's rig build up
  • Hi Toddy,
    it is Ellis Beach .
    Its an awesome spot and when there feels as though you are a million miles away.!!
    its not often the rig is that clean either.
    cheers Joey
    -issue 52 Modified 4wds .
    • Great to see some recent pics of the rig Joey - always an inspiration.
      What happened to the new rims you had lined up?
        Hi Mate,
        yep the mags went on the back burner for a bit as i concentrated on the Camper.
        Last week i had the rig dynoed and serviced adjusted the fuel to air , boost and chip and drined and changed every bit of fluid in her now she is absolutely humming!!
        Also had to loose the Prado Point sticker on the windscreen as it got shattered by a rock and i had to replace it.
        i guess i will have to order a new one now!
        cheers Joey
        cheers Joey
        • Hey Joey, what chip you running? I did a roo systems 3 inch exhaust and Rapid chip. Not real happy with the rapid chip as it stutters when cruising and the chip is coming in and out when on and off load. I was considering Steinbauer as a replacement but have been advised it doesn't like cruise control.
          ...........Heaps of cool stuff
          • HI Sefo ,
            i use DP Chip and have found them to be awesome.
            Love the way they can be adjusted.
            combined with increased and adjustable boost Pressureand 3 inch pipe plus high flow air filter and Bonet scoop its a winning combination.
            cheers Joey
            • here are a few more recent pics.
              cheers.
              • How many inches of lift do you have?
                • Originally posted by buster0z View Post
                  Hi Mate its around 4 inch
                  heres a pic of the stance-
                  joey
                  • Did you have any pics from the Modified 4wd's shoot that didn't get published joey?
                    • Hi Mate i do.
                      i have them at home and when i get back i will post them..
                      might have a few here as well on my laptop i will see what i can find and post them.
                      cheers Joey
                        Hi Madkore,
                        just spoke to the guys at $WDAction and they have a few more they will send through for me to post up.
                        i have soem at home but found these ones on my computer.
                        • how did u get to 4 inch lift and what size tires are u running
