Early's 150 TD Prado
  • Early's 150 TD Prado
    Hi all,
    So, I thought in keeping with the forum spirit of show and tell, here's my build which will cruise along at a speed dependent on how much $$ my swmbo allows me to spend. Lets say it's to take advantage of getting to know the car better before any significant mods start.
    Brand new Nov 2014 GX, Glacier white, auto, and looking like every other soccer mum out there:
    And so the mods begin...
    My white GX auto build thread - [URL="http://www.pradopoint.com/showthread.php?35075-Early-s-150-TD-Prado"][U][B][COLOR="#0000FF"]clicky[/COLOR][/B][/U][/URL]
    Nice blank canvas Early. First mod - number plate
    Baz.
      First up decided to stick on some TJM sidesteps to give me something to step onto when cleaning and fiddling with roof racks, and to stop rocks flicking up and scratching door panels.
      Photo of the chassis rail bracket which will hold the steps in place.
      In keeping with a black and white colour scheme, the alloy has been powdercoated. This will save me from polishing off water marks and also rounds off some sharp egdes
        Haha, Yeah I guess it can be called a mod
        Dealer takes the honours for that one
          After side steps were installed (1hr job), The snorkel was next.
          Before. Last time I see smooth bodylines on this section of the car
          After.
          I got a Tanami snorkel with a trial Wedgetail head which is made by Airtec manufacturer who also manufactures genuine Nissan and Ford snorkels - Australian made and designed, and quality of Airtec.
          The wedgetail design was originally conceived with partnership with Isuzu offroad motorsports as a solution to heavy rain water ingestion by conventional snorkels, and as a solution to snorkel heads being torn off by low-lying branches and vines.
          You can't see the the air intake grill from this angle, but it takes in air flowing over the windshield.
          For me, it adds the bonus of looking different and the option of changing to an Airtec head.
            Instead of a heavy steel bullbar or alloy bullbar which don't seem to fit the teardrop front headlights, I decided to wait and make do with a nudgebar.
            ECB alloy nudgebar powdercoated...black. Quick 30 min job.
              Ordered these a couple weeks before receiving the Prado and have been itching to fit them on:
              Lenso RTE rims 17" by 8.0" with ET20. These are the 4x4 series offered by Lenso. Was originally after the RTC's but out of stock in Australia. Of course.
              And lots of 'umm'ing and 'harrr'ing was done on the choice of tyres, but then thought 'Bugger it, it'll stay on the road till a lift kit' so just transferred over the stock Grandtreks.
              And some roof rails to carry the kayaks.
                They are great looking rims mate, when you get a chance can you post a side on view pic.
                  Hayman Reese towbar fitted with both round and flat connectors:
                  and a Redarc Tow-Pro electronic brake controller on the dash just above the left knee:
                    It's dark outside, but the best i can do with existing phone photos
                    The rear wheels axle needed the center hub painted black because otherwise they're a brown steel colour
                      Yes very nice looking wheels mate
                      Rig build here
                        Never liked fiddling with wires...Wiring up a Narva lightbar for the nudgebar with a Narva Spotlight wiring loom. There is a very small hole on the drivers side firewall which turned out to be perfect for the wire to feed through. Wired to activate with highbeams and switched with a push button which looks identical to genuine buttons.
                        And some genuine rubber floor mats
                          That's the extent of the modifications so far.
                          Things on the list to-do, in no particular order:
                          ScangaugeII Fitted 3/4/15
                          Prorack S16 whispbar roofrack fitted 5/4/15
                          Headlight protector fitted 10/4/2015
                          bonnet protector fitted 10/4/2015
                          Provent200. fitted 28/7/2015
                          Larger tyres
                          Brain's transfer case guard
                          bash plates
                          2" lift kit
                          Whiter Low beam headlight bulbs Philips xtreme vision fitted 6/4/2015
                          side step lights
                          Rear wheel carrier antenna mount
                          External UHF antenna
                          Mobile reception booster antenna
                          stainless steel braided brake lines
                          slotted disc brakes
                          window tinting done 9/5/2015
                          GME hand-held UHF with cradle mount
                          TraxRax?
                            Thanks mate!! I take it Lenso don't make centre caps.
                            kenny5000
                              They do make centre caps, but they are massive things that go over the 6 wheel studs as well.
                              Google image "Lenso RCC" and you'll see the centre caps.
