Leon's 2007 120s D4D GLX
  • Leon's 2007 120s D4D GLX
    Hello everyone,
    I'm Leon the proud owner of a 2007 GLX manual Diesel with 150,000 km based in Brisbane ,
    Im kind of new to 4x4ing it keen to get into it,
    and plan to do a cape trip in 2017.
    here's a picture of as i bought it: Click image for larger version
    i got it with the following:
    - Dual Batteries with red-arc controller wired to 2 extra plugs in the rear and an Anderson plug on the back(that isnt currenlty working)
    - Snorkel
    - Sandgrabber mats
    - Uniden UHF with unknown aerial (if anyone could identify it would be much appreciated) Click image for larger version
    - OEM Bull bar
    - brake controller
    - Toyota alloy bull bar.
    - light force 170MM STRIKER Spotties. (if anyone knows a way to identify if they are halogen or HID model that would be awesome)
    - electronic rust protection
    - under body rust spray
    - Cooper's all terrains
    Planed future mods, (in rough order of priority)
    - Breather extension ( rear, front diffs and transfer case done, Manual box still needs to be done)
    - touch up paint underneath ( done )
    - 2 inch lift (thinking EFS or tough dog)
    - Replace spot light reflectors or replace spotlights
    - Led light bar to put some flood light with the spotties
    - Roof racks ,
    - Small LED bar on the back of the roof rack for reversing.
    - Awning
    - Under body water tank with pump for an after surf shower.
    - Under body protection
    - Roof rack mounting for a shovel, max-trax & possibly an axe.
    - 5x FJ (or similar) wheels with 285x70 r17 tires ( once my current tires run out)
    - Better speakers front and back and a head unit with Apple Car play.
    - Front recovery points
    - Rear Locker
    - Swap the clock and temp readout one that has a compass on it. (has anyone done this?) Click image for larger version
    - Hilux windscreen washers
    and possibly plenty more the more i read through this forum!
    Welcome to the forum, Leon.
    That sounds like a pretty comprehensive list of mods. If you're replacing the spotties, I would just go witht he Supercentre 9" ones. A friend of mine has the light from them is very impressive. IMO the rear recovery points are a waste of time if you have a tow bar. I would just use a recovery hitch in the receiver if you have a bar.
    We will look forward to seeing your updates on this page.
    Greg - 08 D4D Prado,
      Finally order so bush skinz for under the car and 2" lift, kings springs and bilstein shocks, and roof racks.
        speaker surrounds
        i just finished fitting some speakers Ive had lying around for a while to the back.
        i have a 3d printer at work so i printed some plastic speaker surrounds for them.
        i think it worked out pretty good, except i found out the one of the old fusion speakers isn't working so its back to the shops for me.
        Old speakers,
        test fitting the new surrounds
        wired up and foam so they seal
        from the back
        Mounted in place,
        i made it so the front of the speaker is the same distance off the door as the original, so when i get new speakers ill run a ring of foam around them so they seal up with the door card like the originals.
        let me know what you think?
        i could probably make up some more if anyone is interested..
