NTP - 2008 GXL Prado
  • #46
    Originally posted by ntp View Post
    I'll organise some pics over the long weekend.
    No issue with deflation or inflation. The sensor is actually contained within the Tyre (on the rim). The valve is a normal valve except that it is attached to the sensor unit.
    The only issues that I've had were in relation to a couple of the sensors which had a faulty battery. These were quickly replaced by Toyota - so no problems. The batteries are meant to have a 10 year life - and get extra charge from motion as I understand it? So if they last half that time, I'd be happy. Easy to just purchase another sensor unit if needed.
    I don't see why you can't buy extra sensors and add these to however many tyres you might have with your rig. The display will only recognise 5 at any one time, but you can relatively quickly change the sensors to the unit by a quick settings process: you basically set which position (station) the tyre is to be recognised at, then deflate the tyre to trigger the alarm, which identifies it on the system.
    I guess if you also want to monitor a trailer or caravan too, then this is another issue.
    Thanks.
    I think the problems I read about where people complaining that because the air has to go through the sensor after the valve it offers some resistance to inflating/deflating.
    I was just going to purchase an extra sender for my second spare and reset it every time I rotate or change tyres as you suggested.
    2011 150series GXL
