SIK-120 : Steve's 08 D4-D
  • Also this set-up won't work unless you have some nice long flexy coils in the rear, most rear springs will just fall out at max droop
    • Originally posted by Peterpilot View Post
      ooops. Forgot to add rear coils. Added to my previous post.
      Thanks for pointing it out.
      SIK-120
      2008 Toyota Prado 120
      • Hey mate if u don't mind could u give me a rough cost all up and suppliers for these parts? Thanks
        • Just throwing it out there, but I would imagine a set up like that would be around the $4000 mark.
          Its almost at the point that if you are asking, you can't afford it.
          • This is everything that I wanted to do suspension wise.... Unfortunatley it's nothing i can do though as MUMSRIG wouldn't be very practicle for Tam.. But I am certainly in awe of the flex and travel you are getting...
            Nice work!
              Or it could be at the point where no one does a kit or knows much about the prado lifts beyond 50mm so i'm asking!!!!
              • just roughing out the figures...
                $450/pair - MS59-708 FRONT STRUTS
                $220/pair - C59-314 FRONT COILS (middle groove)
                between $450 and $850 - SPC 25470 FRONT UCA'S
                $200 - min. 35mm front diff drop spacers
                $260/pair - C59-443V REAR COILS
                $340/pair - GS59-682 REAR SHOCKS (with sway bar in)
                same as above - GS59-687 REAR SHOCKS (with no sway bar)
                $350/pair - SUPERIOR REAR LCA'S
                $20 - VSPV ext bracket
                $30 to $100 - extended rear brake line(s)
                plus a labour if you can't DIY.
                8608
                SIK-120
                • Relax Justw8 - wasn't having a pop at you.
                  Seems I wasn't that far off if you include labour and a wheel alignment.
                  Superior Engineering do a 4 inch lift for the 120 Prado. cwb has it on his recently purchased Prado - see http://www.pradopoint.com/showthread...0-rig-2004-gxl
                  • Ok madkore bit hard to tell with forums. thanks 8608
                    • That looks great 8608, just one question that I dont think has been asked, how far out is you speedo?
                      • Originally posted by hore1984 View Post
                        From New the speedo was 5% faster than actual speed. 265s put it spot on. Now the speedo is about 8% slower than actual speed.
                        SIK-120
                        • SIK-120
                          • some pics of my last IFS mega flex projects.
                            SIK-120
                            • SIK-120
                              • not ifs, but much much cheaper to wheel.
                                SIK-120
