OK, next job was to replace the leaking radiator. There were a few points around the radiator where it was clearly leaking and it would drip coolant on the shed floor.
I purchased a radiator on eBay from Nationwide Auto Parts after measuring the dimensions of my existing unit - they were very well priced. They shipped the radiator the same day as I ordered it! Delivery was fast but unfortunately Aussie Post had done a number on it and the box was damaged and so was the radiator. I sent Henry at Nationwide an email with a photo of the box and he had me covered with return post and a new unit shipped. This time there were no dramas with the post. I would definitely go through these guys again.
I compared the connectors on the two units to make sure the replacement radiator would fit.
I then drained the existing coolant from the radiator and when it was empty I disconnected the hoses. The coolant in my car was replaced not that long ago so I wasn't concerned about leaving a few litres in the engine / heater. Side by side the old unit looks very old!
Some of the bolts were a bit fiddly to get access to but with a socket extension bar and a shifter I was able to get in there. The new toyota bull bar mounts are really in the way here and I couldn't connect the ratchet to the socket and so used a shifter to turn the socket extension. Not an easily serviceable bolt but got there with a bit of persistence.
Earlier in the day I dropped in at Toyota and purchased genuine coolant - I hear their's is the best. I also grabbed some of the little plastic lock pins that hold down the facia over the radiator - I broke a lot of these removing the facia piece to get at the radiator. I also replaced the hoses and will keep the old radiator hoses as spares.
All up the radiator swap took me about 3 hours including shed clean-up and test drive. I had to re-arrange all of my (just redone) winch loom to get to the bottom radiator bolts. I've never replaced a radiator before but with all the parts on-hand I found it enjoyable and glad to be rid of the stress of a dodgy radiator.
