AJ120s 2009 D4D and DIY camper trailer
This topic is closed.
  • Thankee.
      It's ARB's own brand.
      RRP for the base unit I have is $399, I think a similar amount again for the trailer camera and another $110 for a forward facing camera.
      That's pretty expensive for what it is. I think I paid less for the Parrot asteroid which includes a lot more than just a reversing cam and screen...
      • Of all the factors I took into consideration before buying this, price was barely on the radar. I had a range of criteria, some I have listed above and others that aren't relevant to anyone but me. This system is the only one that met all of my criteria, buying something cheaper that didn't meet my criteria but did a heap of other things I don't need would make no sense to me.
        • Great read, i recently bought a 2008 GXL and have been getting ideas from you.
          I just bought the dual battery volt metre from solidkit, was wandering how you hooked it
          up ? i want it turn on with ignition but problem would the second battery will be always powered on.
          Would have to switch it through the negative wire but is there another option without an additional switch?
          • I have a foot in each camp as to how I hooked mine up, the main battery feed is from the cigarette lighter circuit, so switched through the ignition. The second battery is picked up from my USB power outlets in the rear of the console, so that one stays on permanently.
            You should be able to run the earth wire through a relay that is switched through the ignition, meaning both will come on with the ignition. The problem I see with having them only on with the ignition is that generally you turn the ignition when you start the engine, once the engine is running all they are reading is the alternator output. So the real value in the meter is when the engine is off, which most often means the ignition is off as well.
            • After a bit of googling i found this http://www.the12volt.com/relays/page1.asp
              I will try the wiring for converting a positive output to negative.
              • Sorry to hear that, Andrew. You have been one of the most knowledgeable and innovative posters on the forum.
                Best wishes from in Sydney.
                Greg
                Greg - 08 D4D Prado,
                • Well that is sad
                  Dare I ask where I need to look as to why?
                  Was a pleasure traveling with you and am very thankful for having you and the rest of the SA GTG crew showing me around my home state.
                  Hope to catch you on the trails some day soon.
                  Cheers, Leon
                  Optix Photographix
                  • Originally posted by Corigator View Post
                    Greg
                    x 2
                    • Originally posted by AJ120
                      Pradopoint sticker now removed!
                      The End
                      I hope this is not the end that I think it is. I had the pleasure of reading your trip reports / photos as well as your posts on how to's.
                      2013 ZR in Crystal Pearl With Bits From ARB Catalogue.
                        The End
                        I doubt he'll log in again - but am wishing AJ the best. I've seen people leave and delete all their posts.
                        AJ's reasons for leaving are pretty sound. I personally wish him the best.
                        • Why are people so unkind?
                          [B][SIZE=4]ntp
                            There are a lot of good people on this forum and a lot that have moved on because of a few. This forum has lost one of its best members largely due to apathy and inconsistency. Its almost criminal that AJ plays by the rules including leaving his posts here and others continue to get away with what they do.
                            Its correct, it is very unlikely he will read these comments, about the same chance as Aaron running this as a respectable forum where paid advertisers are treated properly. Enough from me, because it is very unlikely justice will be done other than me being banned for yet again highlighting the fact this forum has a cancer that is getting out of control. That of course will entail someone telling Aaron just like I have let AJ know the well wishes etc.
                            Might go grab the pradopoint calendar I didn't receive and cross off how many days before the next valuable contributor get p155ed off enough and signs out permanently.
                            Disheartened and annoyed - MLC
                              Greg
                              X2 - If anyone is still in contact with AJ, say Hi from us and hopefully we will meet on the tracks some day.
                              • Very sad to see AJ.
                                I wonder when the admin of this forum will start to look after the good people on this forum?
                                Regards, Jason.
