modified '05 V6 GXL ... Butane ...
  • modified '05 V6 GXL ... Butane ...
    first, this is my rig when i first got her late '09
    its a 2005 GXL 4.0l VVT-i with a 6 speed manual gearbox ( 97k on the clock )
    :idea: Started the ball rolling by draining all the lubrication oils from the donk, gearbox, transfer case, and front and rear diffs.
    new engine filter, all topped up with new
    Castrol products sticking with the magnetec 40/15w in the motor
    :idea: Changed out the spark plugs with new densos , the 3 on the pass. side hadnt been done at the 100k service, so it was lucky i checked
    :idea: while i was saving for the big stuff, i whipped up a rear recovery tongue,
    :idea: added VVT-i badging and a black bonet protector
    :idea: The front and rear wheel arch's, where taped and sprayed, spare holder packed out
    :idea: the dollars a reality, the tyres were the first major mod, and honestly, worth every cent. I slipped some Mickey Thompson 5 rib ATZ's under it and evan replaced the brand new GT on the spare for the same... which has already been rotated and put into use
    :idea: with a 45mm lift kit from Ironman siiting in boxes, and a second hand ARB deluxe Bullbar waiting to be modified, it was time to make the prado respectable. I replaced the stock shocks/springs, then sent it in for a camber and wheel alignment
    before............................................ .............after
    :idea: after it was raised, i found the mudflaps didnt look right, so i made some extensions out of 3mm rubber, and still very please with the new look
    :idea: removed the front bumper for a dummy fit up of the bullbar, fly screen installed to protect the radiator, the under side of the lights etc. was blacked out ready for the bar
    :idea: noticed the " non flared bar yet? "
    :idea: about a week later, this is my modified bar painted SATIN BLACK
    :idea: time to give her a good scrub, step back and have a good look
    Re: modified '05 V6 GXL ... Butane ...
    I hadn't noticed it wasn't flared at first but did notice the additional steel you welded on. i had assumed the bar was damaged and didn't think it was for the non flared body. The end result looks quite good. Was the paint a spray (as it seems) or powdercoating/baking. Just curious about the finished strength and resistance to damage from rocks and other.
    [COLOR=#000080]Nick[/COLOR]
      :arrow: Nick, ready for this, the bar is sprayed enamel over the primer, over a rubbed back two pack....
      therefore, my topcoats are basically for appearance... the two pack is for the long haul of weathering/chips etc
      unlike fellow bar owners now i can touch up with ease, lets say any good scratch should only penetrate the top coat, light feather, re coat...
      i plan on touching up with paint instead of polishing a color coded bar, during the bar prep I experimented with re applying coat after coat...
      the blending of layers with the satin paint was a dead set winner.... when i planned the paint i needed the bar to be the same color as the window sills, so it all worked out to my plan to tuff'en it up , so far, pretty stoaked drivin it around... as she's already turnin heads
          :idea: steps off, bottom skirts now satin black, time to make up some tube sliders
            :idea: found a home for my uniden handhelds (uh065sx),................one of my recovery cables (800kgs)
              :idea: sprayed the under side of the bonnet protector BLACK
                :arrow: this is why my radiator has fly screen in front of it... simple mod
                :idea: used a couple of PP stickers to break up the black/silver
                  lets take her out ... Butane ...
                  :idea: strap yourself to me roof and enjoy the driver train'n session.. butane
                  http://www.youtube.com/watch?v=BFK707FE9SM
                    Loving the look of your truck Butane!
                    Good going on the last bit of that hill (up)!
                    What's the setup on your camera? Love the angle and the slight bounce it gives without being all over the place.
                    Cheers - Phil Taylor
                    Prado KZJ120 2006 GX 3.0ltr Manual TJM T13 Bar, Airtec Snorkel, Sand/snow mats, cargo barrier, Cruise, Budget Campertrailer, 8x17" steelies w/ 265/70/R17 Mickey Thompson ATZ 4 ribs, Binatone GPS, Other Stuff...
                      Re: lets take her out ... Butane ...
                      :arrow: cheers phil, ya gunna laff when i tell you i just gaffa taped it to the roof.. no probs ... butane
                        Aaah, love it - nothin better than good old gaffa!
                        Maybe you could sell it on ebay as "smooth action mobile camera mount".
                          another angle
                            flexi flares
                            :idea: reversed " Bushranger 35mm Flexi Flares " added.. :lol:
                              That's actually a pretty good idea.
                              It would also help with reversing into brick walls and just lightly scraping the pain off like I did ops:
